Old 5th February 2008, 06:57 PM   #1
tadiam is offline tadiam  Argentina
Send a message via AIM to tadiam Send a message via MSN to tadiam Send a message via Yahoo to tadiam
Default this amp work?
Old circuit old transistors..70w
audio
Old 5th February 2008, 07:18 PM   #2
unclejed613's Avatar
yes, it works, it's been used by many pro-audio manufacturers. it's a quasi-complementary amp with a diode stack for bias and a single ended input. it was common in the late '60s and early '70's.
Dynaco used a similar design, except theirs had a single ended power supply and a huge coupling cap on the output. the jack plug in the collector circuit was for inserting an ammeter to adjust the bias current. most pro audio designs don't have adjustable bias. they "err on the safe side" and set the output bias just at cutoff, since pro audio amps are rarely driven at low levels, so these vintage pro audio amps have a bit of crossover distortion.
Vintage Audio and Pro-Audio repair ampz(removethis)@sohonet.net
spammer trap: http://www1284177414881.v-dc.net/
Old 6th February 2008, 10:27 AM   #3
Default re
thanks ...how sound this?
mid hi fi.....
audio
Old 6th February 2008, 05:39 PM   #4
latala is offline latala  United Kingdom
Early Wem 100 watt power slaves as used by bands such as the (cream ) i.e.
Jack Bruce,Eric Clapton Ginger Baker etc used a schematic very like this !
I used to repair them I can see no advantage in going back to this scheme
Dc offset was always high and thermally unstable but I am talking re very early days in transistor amplification
regards Trev
Would this work ? LesPaulStandard Instruments and Amps 3 4th May 2006 02:14 AM
Will This Work? sousmielie Class D 6 27th December 2005 05:53 PM
It Should Not Work ! f4bok Solid State 3 6th September 2004 05:33 PM
Would this work? JoeBob Solid State 5 18th July 2003 03:40 PM
Page generated in 0.07912 seconds (69.14% PHP - 30.86% MySQL) with 11 queries
