Old 26th February 2003, 05:20 PM   #1
Ilianh is offline Ilianh  Canada
Ilianh's Avatar
Send a message via MSN to Ilianh
Default MOSFET power follower project
Anyone ever did this project?
Any feedback would be highly appreciated.
I can't seem to find those irf350 anywhere, anyone knows any replacements?
Could be good for a triamp system
Time is the best teacher; unfortunately, it kills all its students
Old 26th February 2003, 06:12 PM   #2
halojoy is offline halojoy  Sweden
On Hiatus
Default Re: MOSFET power follower project
Originally posted by Ilianh
Hi,Anyone ever did this project?
And what MOSFET power follower project
do you mean?
Any special, yours or from some website?
/halo - is not a mind reader - but suspect it has something
to do with a website
Old 26th February 2003, 07:56 PM   #3
Ilianh's Avatar
http://sound.westhost.com/project83.htm
bah...
Old 27th February 2003, 01:34 AM   #4
Ilianh's Avatar
anyone knows if one of those would work? they are all hexfet
(and I have many of them at home)
IRF540
IRF640
IRF740
IRF840
they have similar caracteristics as the irfp350 that I need
(I think the irf740 would be the closest one)
Old 27th February 2003, 02:14 AM   #5
Circlotron's Avatar
The lower the current rating of the fet, for the same current the further up the transfer curve you work it where it is more linear, away from the bottom where it is a big curve. The curvy part means distortion. Monster size fets runnning at low current make more distortion.
/Circlotron - doesn't practice what he preaches.
Old 27th February 2003, 02:32 AM   #6
Ilianh's Avatar
Thx Circlotron for the info.
Well originaly the design is with a IRFP350, wich is
Vdss 400v
Rds 0.3 ohm
Ids 16 amps
the IRF740 is
Vdss 400v
Rds 0.55 ohm
Ids 10 amps
Old 27th February 2003, 09:11 AM   #7
Andypairo's Avatar
Since Vdss is not an issue I'd rather go with 640 or even 540, which have higher current ratings.
Other choiches can be IRFP150, 240, 250, etc, commonly used in similar projects (the former is used in Ciuffoli's Power Follower).
Cheers
Andrea
Old 28th February 2003, 01:30 AM   #8
Ilianh's Avatar
Anyone has any ideas how much power can Ciuffoli's Power Follower output on 8 ohm?
and ayone knows how good are power followers of this kind when the output impedance is 4 or 6 ohm?
Old 28th February 2003, 08:52 AM   #9
argo is offline argo  Estonia
It will depend from rail voltage and bias current.
It will work well into 4 or 6 ohm but you need to feed more current accordingly.
Here is an approximate calculation for different loads
Old 28th February 2003, 06:26 PM   #10
Jay is offline Jay  Indonesia
Power follower type has a low distortion figure. Anyhow, many high-end builders do not appreciate this type of amplifier. The reason is that the overall sound is “dull”. An argumentation to defend this design might be (from my opinion) that this amplifier doesn’t color the sound. It just “passes” the signal from the source. So, you must be very careful in choosing your pre-amp. I guest a bipolar design like Bride Of DOZ will do a great job.
Pavel Macura's MOSFET Power Follower soundNERD Solid State 25 24th February 2011 03:23 PM
Macura dispre with mosfet power follower? sopapo Solid State 10 8th May 2006 09:08 AM
Does anyone has mosfet PP power follower schematic? bogdan_borko Solid State 0 11th December 2005 09:37 PM
Driving a MOSFET power follower RichardJones Pass Labs 19 22nd July 2002 03:02 PM
MOSFET Power Follower help RichardJones Solid State 0 28th January 2002 07:01 PM
Page generated in 0.09207 seconds (87.63% PHP - 12.37% MySQL) with 11 queries
