Hi, this has puzzled me for some time, wonder if anyone has any thoughts. I am thinking particularly at very low amplitudes around the zero crossing point of the audio waveform. I hope the drawing makes what I am trying to say a bit clearer. Any D.C. offset will not effect the linearity of the electronics but if the speaker cone is moved from its "rest" position by the offset, is the cone movement still linear when a small A.C. signal is then superimposed on to it. The movement of the cone caused by the offset may be small, and due to the crossover network will effect only the bass and midrange drive units, the tweeter being A.C. coupled. Anyone any thoughts ?
Karl Last edited by Mooly; 15th January 2012 at 06:24 AM. |
#2 |
If the driver is linear over the range of excursion needed by both the offset and signal, there shouldn't be any problem. If the offset pushes the cone into some non-linear region, that's bad, but hopefully that's nowhere near small signal conditions. I believe all drivers compress with increasing amplitude, so you're thinking the right direction, it just comes down to how much offset, how much signal, and what driver. I don't like much of any offset, just because there's no reason to have it in a good design.
#3 |
Very good point, Karl.
Drivers may have issues with a non-ideal VC resting position, according to information from Klippel (http://www.klippel.de/pubs/papers.asp) From that it might easily happen that a DC offset from the amp might push the driver in either a more linear area or less linear area, from a small signal view. I have measured the T/S-Parameters of guitar speakers and experimented with constant current offsets, which showed a big change in T/S-paramters. Initially I started to investigate these things when I found that I couldn't reliably measure the impedance plot of a specific driver, I got two distinct sets of repetable responses, which where introduced by a small offset of the test amp I used and I didn't take care of the polarity in which I hooked the driver to the amp. Took me quite a while to figure that out. Again, all this is confirmed in the Klippel tech papers. How much of it is really an issue in a good quality 3-way speaker (where only the woofer will be affected)? I don't know... - Klaus |
#4 |
Conrad and Klaus, thanks for your input on this, the big question of course is "IF" the movement is linear. I know how incredibly sensitive our hearing must be, in order to be able to identify differences in performance of equipment/components etc. Imagine how small the cone movement must be if the voice coil is driven with only a few millivolts of signal, yet it is clearly audible. Is it the "quality" or characteristics of the waveform (as it is reproduced by the speaker) at these low levels that goes a long way to determine how a piece of equipment will perform. I wonder how the harmonic stucture would be altered by any mechanical non-linearity. Untill fairly recently offsets of up to 100mv were not unheard of in comercial equipment (a huge amount really). Thanks for the link Klaus, theres a lot of reading to do here. Your testing methods using Thiele/Small parameters are beyond my abilities but I remember doing an impedance plot using a method I read about. A signal generator (low z out) feeds the speaker through a fixed resistor, think it was 600ohms. By adjusting the generator output accordingly you could read off on a D.V.M. (true R.M.S.) across the speaker it's impedance for e.g. 80mv would be 8 ohm. I must get the calculator out and try this again, my current speakers have a 3 ohm minima. My generator has an adjustable offset, wonder whether this would show up on this test, or would the effect be to small to measure. Thanks again for a bit of lively debate.
Regards Karl |
#5 |
*any* offset will,imo, produce nonlinearity from the mechanical parts, surround, spider, ect.
Just as installing a driver facing up. How much? driver dependant.
Just because you can't hear it doesn't mean no one can. |
#6 |
the effect you are describing is real and I think the answer to your question is yes, a DC offset causes distortion. How much and how audible is another matter. But the principal is correct, the DC offset causes the cone to be displaced from its normal rest location. AC signals do not remove the offset, it persists in the presence of the audio signal. I think the best response is to find an amp with very small offset, mV, if possible or adjust for low offset.
Ted |
#7 |
I guess the ultimate "test" is to introduce an offset and do some critical listening. As mentioned earlier about impedance curves, it is 600 ohm fed by 6 volts R.M.S. in series with the speaker. Read off in millivolts is proportional to impedance e.g 80mv equals 8 ohm. Credit for this simple method goes to Doug Self, but it is easy and revealing to do.
Karl |
#8 |
Piano waveforms are known to exhibit as much as 12dB of asymetry, a few millivolts of DC off-set will not be noticed (unless your speaker has an x-max of 0).
The ESP site has examples of tone bursts of asymetrical signals that show what seems to be several volts of off-set when run through a typical amplifier. This can be a problem with PA, and destroy woofers. Crown has a circuit called a loudspeaker off-set integrator to reduce this on their vz5000 amplifier.
Candidates for the Darwin Award should not read this author. |
#9 |
Depends on a no of things !One being the type of enclosure that is used for the spk. A small infinite baffle (acoustic suspension ) can be asymetric ie a regards cone loading
Maybe if the offset was in the correct direction it might reduce distortion ? All though I feel that if the amp has more than 50 mv offset then you have problems with the amp any way in this day and age it should be around 5-10 mv no more ! regards Trev |
#10 | |
- Klaus |
| Linear Power 1502IQ distortion at low volume | 0ldSch00lf00l | Car Audio | 2 | 1st October 2008 05:18 AM |
| Off-axis non-linear distortion | JohnG | Multi-Way | 1 | 23rd June 2008 10:46 AM |
| Non Linear Distortion testing - Harmonic Distortion | JMB | Multi-Way | 0 | 20th July 2004 02:54 PM |
| Nonlinear harmonic distortion vs. linear harmonics | capslock | Multi-Way | 0 | 6th September 2002 09:40 AM |
| Page generated in 0.11574 seconds (80.40% PHP - 19.60% MySQL) with 11 queries |
