Pictures of your amplifier's case
Old 27th February 2003, 12:10 AM   #11
KenP is offline KenP
While it's not an amp I built the case out of 1/2" mdf and cut the front and back from a piece of 1/8" aluminum sheet that I had. The case is painted with black stone paint and a final coat of clear. The three knobs are from an old Yamaha receiver that I scrapped.
[/URL]Click the image to open in full size.
Old 27th February 2003, 07:01 AM   #12
Mr. Triatic is offline Mr. Triatic  Sweden
Mr. Triatic's Avatar
here´s mine JLH-type amplifiercase, made out of 3 large heatsinks with top, bottom and front by polished Dur-aluminium
sorry for the bad picture...
http://home.swipnet.se/sm6xun/Image2.JPG
www.joddla.net/audio/
Old 27th February 2003, 08:53 AM   #13
Steve Eddy is offline Steve Eddy  United States
Steve Eddy's Avatar
Mmmm. Don't have a digital camera so a CAD drawing will have to do.
<center>
<img src="http://www.q-audio.com/images/littlechassis.jpg">
</center>
Click here for a <a href="http://www.q-audio.com/images/bigchassis.jpg">larger view</a>
It's designed around the <a href="http://www.accelindustrial.com/model79.gif">Model 79</a> extrusion from <a href="http://www.accelindustrial.com/">Accel Thermal.</a>
Except for the heatsink and screws, the chassis is all wood.
The fins are facing outward from the front and the heatsink is gold plated (purely for aesthetics, and the reduced heat capacity isn't a problem for this little 6 watt amp).
The outside open-ended box is made of 3/8" cherry with a 1/16" chamfer around the front and rear outside edges. The four inside surfaces are covered with 1/16" natural cork.
The strip down the middle between the groups of fins is 1/4" birdseye maple with a 1/8" chamfer around all four edges. The hole near the bottom is a power indicator LED.
The strip mounts to the heatsink using four 7/8" brass standoffs and 4-40 thread brass machine screws (yes, you can use machine threads in certain hardwoods like hard maple).
The rear panel is 1/4" birdseye maple with a 1/8" chamfer around the outside edge. The screws are all 4-40 thread brass fillister head machine screws in 1/4" diameter by 1/8" deep counterbores (the counterbores on the outside edges were done on a router table using a simple jig so that the piece could be slid square on into a 1/4" straight cutting bit).
The groups of 1/8" holes at the top and bottom of the rear panel are ventilation holes.
The rear panel is attached to the heatsink via the four inner screws and 3/4" standoffs. The rear panel/heatsink assembly act as one unit and are slid in trough the back of the open-ended box and the rear panel seats into a 1/4" wide by 1/8" deep rabbet in the open-ended box.
The heatsink fins and center strip stand 1/8" pround of the front edge of the open-ended box.
The spacer block is hard maple and the base is a solid block of big leaf maple burl.
Countersunk inside the bottom side of the open-ended box are two 6-32 stainless steel T-nuts to receive the mounting screws which run up through the bottom of the base.
The feet are made of 3/8" natural cork.
The chassis isn't limited to a vertical configuration. I just preferred it and I liked the smaller footprint. You could just as well route your connectors through one of the sides of the open-ended box, dispense with the base and lay it on its back.
Feel free to use any or all of these ideas.
se
Old 27th February 2003, 10:22 AM   #14
Koy is offline Koy  Czech Republic
Here is my amp.
Old 27th February 2003, 11:02 AM   #15
Bricolo is offline Bricolo  France
Bricolo's Avatar
Originally posted by Koy
Here is my amp.
sweet
what's this nice looking button, with the red light?
Old 27th February 2003, 11:15 AM   #16
SkinnyBoy is offline SkinnyBoy  Australia
Banned
Send a message via MSN to SkinnyBoy
Originally posted by KenP
While it's not an amp I built the case out of 1/2&quot; mdf and cut the front and back from a piece of 1/8&quot; aluminum sheet that I had. The case is painted with black stone paint and a final coat of clear. The three knobs are from an old Yamaha receiver that I scrapped.
I like it... I copy it.. now.. 2 of them, one for my homeless computer, one for my future amplifier... MATCHING PAIRS!! Hmm.. I was going to buy rack cases, too expensive, too small, now I have another option!! THANKYOU!!
Old 27th February 2003, 11:36 AM   #17
Bricolo's Avatar
I also plan to use this design for my gainclone, all metal with those cute screws
A 5mm front pannel made of glass, over the metal front, would look nice imho
Old 27th February 2003, 04:00 PM   #18
Bricolo's Avatar
something that would look like this computer case, but with the glass that maches the front pannel's dimentions
Old 27th February 2003, 06:53 PM   #19
GringoAudio is offline GringoAudio  Canada
Using Scrap extrusion from work, .060 sheet aluminum. 3/16 x 4" aluminum sides. Will be brushed. For LM 1875 stero amp with 225 VA toroid. It will be done in a week or so.
Old 27th February 2003, 06:56 PM   #20
inside
Pictures of your amplifier's caseHide this!Advertise here!
Wow.. amplifier case. arnach Solid State 47 19th September 2013 03:53 PM
Building an amplifier case Tripmaster Chip Amps 5 11th November 2008 06:32 PM
Amplifier case / housing GeeVee Swap Meet 8 4th August 2008 01:11 PM
Case (chassis) for the amplifier j3qq4 Chip Amps 0 26th July 2007 08:26 PM
case work pictures Per Nielsen Everything Else 9 10th February 2003 08:01 AM
Copyright ©1999-2017 diyAudio
