How to cut large heatsinks?
Old 31st January 2008, 02:20 AM   #1
bobgroger is offline bobgroger  United States
Question How to cut large heatsinks?
I have 2 heat sink extrusions measuring 5X8X25 inches. I would like to cut each one to 6" lengths. Can this be done reasonably accurately in a DIY fashion, or should I find a machine shop? What would a reasonable price be per cut?
Bob G.
Old 31st January 2008, 04:24 AM   #2
herm is offline herm  United States
I did a thread on cutting aluminum.
Here's the link:
Cutting Aluminum Thread
If you have experience with power tools, its fairly do-able.
If you don't I wouldn't recommend it.
Sorry about all the drama in that thread
herm
Old 31st January 2008, 05:45 AM   #3
krazatchu is offline krazatchu  Canada
Those are large pieces... in metric 12.7 x 20.32 x 63.5cm...
I would use a chop-saw or a bandsaw with a metal blade...
Perhaps there is a local junkyard/salvage yard... where they might have a chopsaw...
Wouldn't take more than a few minutes and shouldn't cost much...
You could also try a highschool, if they have tech classes you could get a student to do it...
Old 31st January 2008, 06:38 PM   #4
Minion is offline Minion  Canada
I used a Chop saw to cut a 12 in x 10 in Heatsink into 3 Parts, It was hard to get a proper straight edge when cutting but was able to grind the edges smooth with a grinding tool...Didn"t take long and was pretty easy...I suggest you put the Heatsink in a stable vice before attempting to cut....
Cheers
Old 31st January 2008, 07:01 PM   #5
Here's the link:
herm
Thanks, lots of good info there.
Bob G.
Old 31st January 2008, 07:42 PM   #6
cuibono is offline cuibono  United States
cuibono's Avatar
I didn't read the above thread, so I might be repeating, but I've cut heatsinks with:
a hack saw - works well, but maybe slow, and doesn't cut deeper than a few inches.
a masonry blade, in a table saw: worked quickly, straight cut, danger from sparks + sawdust. I assume you could put the blade in a circular saw too, but you've got to clamp it real well. I'd bet a diamond blade for cutting tile might work too.
I've even used a regular hand saw (for wood) one night when I was desperate. A reciprocating saw with a metal blade would work too..
Old 31st January 2008, 07:50 PM   #7
poynton is offline poynton  United Kingdom
poynton's Avatar
I used a tile cutting saw with a diamond disk
Andy
Old 31st January 2008, 08:54 PM   #8
quasi is offline quasi  Australia
quasi's Avatar
If you have access to a mill, this is how I cut mine.
The large heatsink was clamped to a heavy angle bracket which was bolted to the mill table. Nice and slow but dead accurate. Note the use of lubrication during the cut.
Cheers
Quasi
How to cut large heatsinks?Hide this!Advertise here!
FS: 4 large heatsinks Killjoy99 Swap Meet 6 3rd April 2008 01:24 AM
FS: Large Heatsinks Bakmeel Swap Meet 3 17th October 2006 05:58 PM
FS:4 large heatsinks 0.3K/W Thomas Swap Meet 0 10th October 2005 10:01 PM
Large Heatsinks anyone Rixsta Parts 9 27th April 2004 02:40 PM
Copyright ©1999-2017 diyAudio
