Hi guys,
I am looking at buying a couple of amp kits based on the MJL21193/94 - it is rated at 200W into 8R and 350w into 4R - The specs in class a/b mode are -1db at 15Hz and 60kHz -0.002% THD at 150w 8R (10hz - 22KHz) -SNR -122dB unweighted (22Hz - 22kHz) @ 200W into 8R -Damping factor 75 at 10kHz with respect to 8R Now I was wanting to know if it would be minor to bias this into class A to get around 60W into 8R - Im guessing the +-70 volt rails will need to be alot less and the bias changed but can anyone see any issues in doing this? I have attached a schematic so you can see the design - thankyou for any input. |
#2 | |
you'd be better off getting an amp designed for class A rather than doing a mod like this.
Just because you can't hear it doesn't mean no one can. |
#3 | |
#4 | |
I'd have a real problem believing some of the quoted numbers, especially the THD. |
#5 |
That amp has been in the "trouble section" here before.....
Be carefull
Free Schematic and Service Manual downloads www.audio-circuit.dk, Company: www.dupont-audio.com, Joint venture: www.DupontMantra.com |
| class d turn on thump | jol50 | Car Audio | 15 | 9th July 2009 08:31 AM |
| Full-turn/partial-turn pots | slowpogo | Parts | 1 | 12th January 2007 07:40 AM |
| Q: Class-D Amp Kits, All, Turn-on Thumps | speaker | Class D | 5 | 15th November 2006 05:47 PM |
| Turn-off Pop in class-d amps | KT | Class D | 4 | 4th November 2005 10:34 PM |
| How can I reduce mechanical turn on and turn off noise? | soundNERD | Chip Amps | 8 | 28th October 2003 01:43 AM |
| Page generated in 0.09575 seconds (74.37% PHP - 25.63% MySQL) with 11 queries |
