Transformer with uneven ac out - diyAudio
Old 25th January 2008, 08:45 PM   #1
geminni is offline geminni  Serbia
Default Transformer with uneven ac out
I need 2x15v supply for preamplifier. I have a transformer with two output. One is 23v and second is 30v. Two windings are connected together.
Can i connect it to a rectifier? Will this voltage difference bother?
If it is ok then i will also use zener, transistor to lover voltage at 15v dc.
Old 26th January 2008, 04:44 AM   #2
Jan Dupont's Avatar
Send a message via MSN to Jan Dupont
You can use 15V zener regulation to get your needed +/-15VDC with no problem as long as both the 23 and 30VAC outputs can deliver the Current you need
Free Schematic and Service Manual downloads www.audio-circuit.dk, Spare time company (just for fun): www.dupont-audio.com
Old 26th January 2008, 11:50 AM   #3
or add the 7Vac winding to the 23Vac to match the 30Vac.
Check which winding has the smallest wire diameter. This becomes the effective limiter of your output current.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 26th January 2008, 12:40 PM   #4
So, the voltage difference will not make things go bad
Ok, i'll try that and adding that 7 volt in seres with 23v.
Thanks guys!
Old 31st January 2008, 05:13 PM   #5
It's working!
Now i have +-40,5V. How can i make +-15V for preamp?
I have been looking in LM317 data sheet, looking on net and found that its maximum input voltage is 40v.
Would the classic zener-transistor combination be enough for preamp?
I ask because i have made same setup for amplifier with TDA1516q and it distorted very bad on higher power output. When i replaced zener-transistor with 7815 it worked very nice. No distortion on louder volume.
Old 31st January 2008, 08:45 PM   #6
Use the transistor-zener as a "pre regulator" to drop down to about 25V or so... then use LM317/337 or 7815/7915 to supply the preamp.
Alternatively build something like the Jung or Sulzer discrete regulators, but that's a lot more complex.
Old 1st February 2008, 05:52 AM   #7
Thanks! I'll try that with 2 stage voltage drop
Isobarik with uneven signals mashaffer Subwoofers 6 30th May 2006 08:47 PM
Uneven voltage on PS chipco3434 Power Supplies 11 22nd February 2006 02:10 PM
uneven output on my 206 carlos671 Digital Source 2 6th December 2005 03:10 PM
uneven wound 50w OT 2 ideas...? dud_wity Tubes / Valves 13 29th March 2004 12:54 PM
Copyright 1999-2017 diyAudio
