Hi all,
how polarised jfet for have a perfect clipping? i want to built a line stage preamp single ended with gain of 10-12 db but when i have my perfect gain i have a problem with my clipping, positive peak clip but not negative. Why? Somebody can help me! thank you! Maxpou |
#2 |
We can't help you unless you post a circuit diagram of what your trying to do.
Leigh
The perfect amplifier is a piece of wire with gain.... |
#3 |
Hi Nitrate,
i have this problem with one jfet. Schematic is a exemple. thank you! Maxpou |
#4 |
what is the voltage on the output? How far can the output voltage swing until either rail starts to limit? Can you move the quiescent bias voltage on the output to equalise the available swings to either supply rail?
regards Andrew T. |
#5 |
Did it Himself
The reason is that the constant current source needs a finite voltage across it to work properly.
www.readresearch.co.uk my website for UK diy audio people - designs, PCBs, kits and more |
| Oppo 980 SACD clipping problem | millon | Digital Source | 4 | 13th January 2009 12:04 AM |
| PC sound output clipping problem | hajame | Digital Source | 3 | 29th April 2008 04:39 AM |
| Problem w/Clipping new 2 car audio need help | bmxkris | Car Audio | 2 | 4th April 2005 05:27 PM |
| Clipping GC? | drfrink24 | Chip Amps | 29 | 1st April 2005 10:14 PM |
| Help with +VE clipping | matth | Solid State | 7 | 21st June 2003 07:03 AM |
| Page generated in 0.07732 seconds (70.02% PHP - 29.98% MySQL) with 11 queries |
