Preamp - Overheating Xformer (Without Load) but Not Blowing Fuse
Old 21st January 2008, 12:56 AM   #1
dtm1962 is offline dtm1962  Canada
Default Preamp - Overheating Xformer (Without Load) but Not Blowing Fuse
I have a B & K preamp with an outboard Power Supply ( Basically a transformer with 25V + 25V & 10V + 10V secondaries) that is overheating (extremely hot melting adjacent plastic fuseholder and its own clear plastic insulation BUT..... still supplying the correct voltages and not blowing the small 0.5A primaries side fuse.
It gets hot even with the preamp load disconnected!!!!!
Can someone tell me what is happening???
Has anyone experience this situation?????
Is the insulation on conductors shorting out or what???
I included a photo of the damage as well.
Any help would be appreciated.
Thanks in advance,
Dan
Old 21st January 2008, 01:08 AM   #2
Conrad Hoffman is offline Conrad Hoffman  United States
Look for shorted diodes, bad capacitors and such, if they're part of the circuit. Most likely it has a shorted turn somewhere. Also, if that bolt through the center touches the disk, and the disk somehow touches the chassis, that would create its own shorted turn. If you put it on a bridge, you could see the shorted turn by the high dissipation factor. Anybody got any other simple methods?
Old 21st January 2008, 02:35 AM   #3
Bonsai is offline Bonsai  Europe
I'd go with th e shorted turn theory - but strange that th eprimary fuse is not blowing.
Another suggestion: disconnect the transformer secondaries from the rectifiers (i.e., secondaries open circuit). If it still gets hot, its th e transformer. If not, its in the rectifiers or caps.
good luck.
Old 21st January 2008, 03:03 AM   #4
I just took anothe r look at th e phto - looks like there is no rectifier or caps in the PSU box. If this is indeed true and its getting hot with no output connection, the problem mus t lie around the transformer.
If you run the supply as shown in the photo with the transformer out of th e box and it still gets hot, you probably have an internal transformer problem - shorted winding etc. If it run s cool - your transformer mounting is a problem as described earlier in this thread.
Old 21st January 2008, 03:08 AM   #5
So you think the insulation has failed and it is shorting out on the core or adjacent/overlapping conductors?
The voltages are still 25V and 10V as specified.
Does this shorting affect the output voltage????
I still can't understand why the fuse does not blow when connected OR NOT connected to load. It heats up enough to melt plastic!
Thanks in advance,
Dan
Old 21st January 2008, 03:10 AM   #6
Yes you are correct there is just the noise filter and fuse on the primaries and nothing other than the 5 pin connector (to mate to preamp on the secondaries. The bridge & the PS Caps are in the preamp and will not affect the load if the cable is not connected from this outboard PS Box.
Thanks,
Dan
Old 21st January 2008, 04:02 AM   #7
Can you measure the primary current?
I'd expect for a well designed transformer with no load this would be tens of mA (maybe 50-100mA max).
Old 21st January 2008, 05:41 PM   #8
megajocke is offline megajocke  Sweden
megajocke's Avatar
Did you try disconnecting all the secondaries? There could be a short in the cable or connector. If a secondary with relatively low power is shorted that winding can overheat without blowing the primary fuse.
A shorted turn won't change the output voltage much. It is possible for the fuse not to blow, the fuse will allow 50W/100W (depends on line voltage) to be dissipated somewhere. If dissipated in a localized spot even less than a tenth of this will be more than enough to melt the insulation. If it has a shorted turn the heating would tend to be localized. Is the whole transformer getting hot after a little while or is it a localized area that is getting hot? A shorted turn will get hot pretty fast compared to overloading a transformer.
Old 22nd January 2008, 04:42 PM   #9
Default WTB: Sanken SAP15N & SAP15P (or STD03N & STD03P if compatible)
I have the Cambridge Audio A500 integrated amp with the blown output devices.
I cannot find a source to purchase unless I buy 1000 min. quantity.
The distributor will NOT supply samples to me/my company of either set. (assuming the SAP versions is obsolete)
Does anyone have 2 pairs of either devices to SELL in order for me to use in my amp.
Can I use the STD03 series without too many mods ? (Add a resistor on the emitter etc.)
Dan
Old 22nd January 2008, 04:45 PM   #10
Ignore last post as I entered in this thread versus an new one in the Market Place.
Sorry.
Anyways I will be spending some time looking at my problem with the Power Supply.
I will take measurements to determine if it is the transformer shorting out or the cable has a problem.
Thanks,
Dan
Preamp - Overheating Xformer (Without Load) but Not Blowing FuseHide this!Advertise here!
Fuse housing melting but fuse not blowing, ppi amp rawadia Car Audio 21 2nd August 2008 10:39 AM
Blowing B+ fuse trombone Tubes / Valves 5 1st July 2008 02:05 PM
Strange: Preamp Xformer Overheating but Not Blowing Fuse and Supplying Right Voltages dtm1962 Parts 4 29th January 2008 12:18 AM
Blowing my fuse (s) Jimlondon Chip Amps 7 7th March 2005 06:03 PM
Copyright ©1999-2017 diyAudio
