Old 21st January 2008, 12:05 AM   #1
hobbit is offline hobbit  Italy
Question Simple amplifier
This is my first post. My english is bad.
I want make a amplifier that must to be:
- simple and fast to assembly (good kits or universal board, ....);
- have good sound (better of my Nad 302);
- good for listen classic, spirituals, country, ....;
- working with 89-90db speakers (I don't know the power necessary);
- very cheap;
- well bjt, fet, chip, t-amp, .tube, ....
Give me an idea?
Bye,
Francesco
Old 21st January 2008, 12:49 AM   #2
tinitus is offline tinitus  Europe
http://www.aussieamplifiers.com/index3.htm
This new 100watt amp might be worth a try, and he can deliver complete supply boars, easy and safe
Old 21st January 2008, 01:38 PM   #3
using cheap as the most important criteria, then you can remove tube from your options.
Chipamp or very simple BJT could get what you need.
For 89 to 90db/W/m speaker try for 50W to 100W.
If your speakers are 8ohm then lm3886 might be your solution.
Small PCB and low component count= cheap, kits= easy to build,
Have a look at some of the chipamp threads, Nuuk's Decibel Dungeon and look at the ESP site.
regards Andrew T.
Old 21st January 2008, 01:41 PM   #4
Thank you for reply.
This project is well but it isn't cheap. I don't need 100w, is excessive for my listen.
Bye,
Francesco
Old 21st January 2008, 01:48 PM   #5
Default Re: Simple amplifier
Originally posted by hobbit
.............- working with 89-90db speakers (I don't know the power necessary);...........Give me an idea?
Originally posted by hobbit ........ I don't need 100w, is excessive for my listen.
do you want or need assistance?
regards Andrew T.
Old 21st January 2008, 04:00 PM   #6
I use 40-50watt...but there are different kinds of 50watt, and my small monsteramps are no doubt much more powerfull than a small chipamp
"41hz" have some interesting amp kits, and quite cheap...personally I dont know them
The 100watt from AussieAmp may also be configured as a 60watt, lowering the voltage
Old 21st January 2008, 09:42 PM   #7
I think that 20-30w is sufficent because my Nad 302 has 25w and it's sufficient for me. Bur I don't sure.
Thanks. 41hz is interesting. Which is best amplifier of 41hz? (good sound)
Best regards,
Francesco
Old 21st January 2008, 10:15 PM   #8
Without knowing, fore you I would say "Amp10" looks interesting with onboard supply and ordinary hole mounting, meaning easy easy to build
Old 23rd January 2008, 09:49 AM   #9
defect9 is offline defect9  Ireland
defect9's Avatar
i found simple, and low cost.
http://www.audiosector.com/lm3875.shtml
the dual mono classic: $57 (can be run off a transformer with dual secondaries)
add appropriate transformer(s), available from various places, something local. look for ones with 24v taps and between 150 and 300VAC (if these numbers are wrong, someone correct me please)
the rest is the basics. potentiometer, power switch, Mains jack, RCAs, etc. and case, obviously.
-Jared
Old 23rd January 2008, 05:14 PM   #10
Thanks.
I'm undecided, T-amp way or gainclone-way.
Which is better? Which has better sound?
I don't know t-amp and gainclone sounds.
Bye,
Francesco
Simple Hi-end 845 amplifier audiodesign Tubes / Valves 57 2nd January 2009 07:09 PM
simple Amplifier? technics Solid State 38 31st March 2008 11:36 PM
REALLY simple amplifier? CalcProgrammer1 Solid State 19 28th November 2007 10:37 PM
simple amplifier bigspeakers Chip Amps 4 23rd June 2006 12:34 PM
need a simple amplifier DrSplodge Everything Else 12 28th July 2004 06:49 AM
Page generated in 0.10865 seconds (78.16% PHP - 21.84% MySQL) with 11 queries
