Old 20th January 2008, 10:18 AM   #1
sajti is offline sajti  Hungary
Default JLH output stage
I found this output stage in JLH's book. But something is strange for me: What is the current of MJE15033s, if the output stage has 100mA bias?
sajti
Old 20th January 2008, 10:23 AM   #2
Jan Dupont's Avatar
Send a message via MSN to Jan Dupont
6 mA + the Base Current to the output device I would Guess by calculating in my head.......
Free Schematic and Service Manual downloads www.audio-circuit.dk, Company: www.dupont-audio.com, Joint venture: www.DupontMantra.com
Old 20th January 2008, 10:28 AM   #3
And in this case what is the current of the BDs?
sajti
Old 20th January 2008, 10:32 AM   #4
My calculation is the following:
The current over R3 is ~6mA, due the output devices are open.But the current over R5 must be ~6mA as well. Because if it less, than the MJE-s are switched off. So I think that the current over the MJEs is equal with the base current of the output devices. Is it OK?
sajti
Old 20th January 2008, 10:45 AM   #5
Jan Dupont's Avatar
You have to take the BD's into the calculation...
I have never tried this output stage, but the BD's can feed the Bases of the MJL's directly.......
Old 20th January 2008, 10:54 AM   #6
Of course, but not 6 pairs of MJLs for 2ohms... So I think that I will try to reduce R3 and R4 to 22ohm, to get bias for the MJEs.
sajti
Old 20th January 2008, 11:01 AM   #7
Jan Dupont's Avatar
Why ??
Only result would be to drive the driver and predriver harder ??
The total Base Current to 6 MJL's at 100mA idle would be app. 20 mA. That would be total app. 26 mA with R3=100R but 47mA with R3=22R.....
Old 20th January 2008, 11:09 AM   #8
I plan to use it with valve VAS, so I need triple darlington to get high input impedance.
I have lot of MJE15032/33, but I was not able to select NPN/PNP pairs, because the '33s have much higher B. So I try to find output stage with same polarity driver, and output
sajti
Old 20th January 2008, 11:14 AM   #9
Why ??
Yes, but the base current of the output devices is not well defined. And the lower value resistor result faster switch of for the output devices. With 100ohms, and 6 pairs the output stage will be 6 times slower..
sajti
Old 20th January 2008, 11:26 AM   #10
Jan Dupont's Avatar
The Base Current are as well defined as on all other transistors ?
Hfe 25 to 75.....
What do yoy meen by slower ?
3C24 in a SE output stage - output transformer impedance recommendation !!! aldovan Tubes / Valves 15 6th September 2008 10:18 AM
preamp output stage resistor from output to V- ? ? Bernhard Solid State 4 19th October 2007 02:55 PM
Output stage biasing, with the driver stage andrew_whitham Tubes / Valves 0 19th May 2007 11:14 AM
Adding secondary of output transformer into cathodes of output stage ? Eico ST-70 freddymac406 Tubes / Valves 3 21st April 2007 06:15 PM
TV Horzontal Output Transistor for output stage..? ronybc Solid State 46 10th October 2005 02:26 AM
Page generated in 0.11406 seconds (73.83% PHP - 26.17% MySQL) with 11 queries
