Where can I find ssm2210 transistors... - diyAudio
Old 25th February 2003, 12:16 AM   #1
Guiness is offline Guiness  United States
Guiness's Avatar
Default Where can I find ssm2210 transistors...
I have a project that requires these audio transistors (ssm2210). But I have not been able to find these anywhere. Maybe I have not been looking in the right places. Any help would be appreciated...
Thanks again
Old 25th February 2003, 12:20 AM   #2
jackinnj's Avatar
Default newark electronics has them in stock
when you need a super-matched pair consider using a transistor array -- they are all cut from the same die.
Old 25th February 2003, 01:09 AM   #3
martioz is offline martioz  Australia
Try RS Components, I bought from them last year.
Also you can use MAT02 or similar.
Old 26th February 2003, 08:44 AM   #4
MAT02 is actually the same thing in a different case and with lower offset and higher price. While linearity of the SSM parts is excellent, I would not use them in anything but a low noise MC amp. The reason is the really high parasitic capacitances. There are other dual transistors specifically designed for audio such as 2SA1240 or 1349. Unfortunately, they are discontinued just as the 2210.
Eric
Old 26th February 2003, 10:10 AM   #5
Default SSM2210
You can try Farnell!
Old 26th February 2003, 12:28 PM   #6
Electrons are yellow and more is better!
peranders's Avatar
Default Re: Where can I find ssm2210 transistors...
Thanks again
SSM2210 = MAT02, difference is package, only
SSM2220 = MAT03
I have plenty SSM2210 and SSM2220 for sale.
SSM2220/10 is no longer in production unless you want >100 000 pieces, according to Analog Devices.
/Per-Anders (my first name) or P-A as my friends call me
PA03 LM4780 amplifier group buy, SIGN UP HERE for the group buy 0 boards left. 118 paid.
Old 26th February 2003, 12:35 PM   #7
peranders's Avatar
You could also use BC847BS, only 20 cents and rather good. It's like two BC547/847 in the same package. I have tested it and it works very fine in a differential input stage.
Old 26th February 2003, 03:00 PM   #8
PCP is offline PCP
PCP's Avatar
Default LM194 & LM394
Another ultramatched pair of ultralow noise BJTs, no Idea of where the [...] it can be found. Farnell and Rs I suppose.
It's still in production, also in DIP package (cheaper than metal cans TO-71 and TO-78)
BC547BS has really much more noise than ssm2220, MAT02 and LM194/394. non suitable for an MC preamp, but ok for a power amp.
But only if you manage to solder it, I've 5 of them and I still spend 5 minutes everyday looking at them, thinking how will I solder it...
Old 26th February 2003, 03:46 PM   #9
cHoc is offline cHoc  Netherlands
Send a message via MSN to cHoc
and also if you use two BC547's instead of an MAT03 or SSM2210, it's best to match them, but even then they problaby will funtion less than a SSM2210
Old 26th February 2003, 04:52 PM   #10
peranders's Avatar
http://www.thatcorp.com/
They make also matched pairs.
What is important?
Low noise
High gain
Matched electrically
Temperature tracking
All mentioned types don't have everything
BS847BS is everything except for extremely low noise and extremely matched. As an input transistor it's suitable for almost everything expect for MC preamps. This type is very price worthy. If you can solder it, test it! But beware, nothing for a newbeginner in soldering. Check my picture and compare the size.
The transistor has the same body as SOT23 but with 6 pins.
Cant find transistors! manysimplething Solid State 1 5th April 2008 03:06 AM
Need to find these transistors profuse Parts 2 20th August 2007 09:40 AM
can't find good complementary transistors keantoken Parts 28 13th September 2006 12:22 AM
WTB hard to find transistors mmerig Swap Meet 1 24th January 2006 07:55 PM
SSM2220, SSM2210 Ultra super low noise matched monolithic transistors pairs peranders Swap Meet 0 18th April 2002 08:58 AM
Copyright ©1999-2017 diyAudio
