Old 19th January 2008, 06:17 AM   #1
unclejed613's Avatar
Default 2SA1011/2SC2344 models needed
i'm needing SPICE models for these bjts, and i already searched the web. Agilent SELLS a spice library with them in it. any suggestions?
Vintage Audio and Pro-Audio repair ampz(removethis)@sohonet.net
spammer trap: http://www1284177414881.v-dc.net/
Old 19th January 2008, 11:37 AM   #2
Send a message via Yahoo to linuxguru
Not a reply to your query, but I'd also like unencumbered Spice models for:
2sa965/2sc2235
2sa1930/2sa5171
2sa1016/2sc2362
2sa1538/2sc3953
TIA
Old 19th January 2008, 12:37 PM   #3
aparatusonitus's Avatar
.model 2sa965 PNP(
+Is=4.956p
+ Xti=3
+ Eg=1.11
+ Vaf=100
+ Bf=156.1
+ Ise=4.957p
+ Ne=1.434
+ Ikf=3.085
+ Nk=1.053
+ Xtb=1.5
+ Var=100
+ Br=1.02
+ Isc=2.06n
+ Nc=1.35
+ Ikr=3.312
+ Rc=.5442
+ Cjc=2p
+ Mjc=.3333
+ Vjc=.75
+ Fc=.5
+Cje=5p
+ Mje=.3333
+ Vje=.75
+ Tr=10n
+ Tf=1.324n
+ Itf=1
+ Xtf=0
+Vtf=10)
.model 2SC2235 NPN(
+ IS=2.2874E-12
+ BF=193.91
+ VAF=100
+ IKF=1.4742
+ ISE=2.2874E-12
+ NE=1.3496
+ BR=3.5606
+ VAR=100
+ IKR=53.900E-3
+ ISC=21.348E-9
+ NC=1.9528
+ NK=.70855
+ RC=.22419
+ CJE=2.0000E-12
+ CJC=60.728E-12
+ MJC=.33333
+ TF=1.0969E-9
+ XTF=10
+ VTF=10
+ ITF=1
+ TR=10.000E-9)
.model 2SC5171 NPN(
+ IS=10.000E-15
+ BF=210
+ VAF=100
+ IKF=10.000E-3
+ XTB=1.5
+ BR=.1001
+ VAR=100
+ IKR=10.000E-3
+ ISC=10.000E-15
+ CJE=2.0000E-12
+ CJC=38.866E-12
+ MJC=.33333
+ TF=83.239E-12
+ XTF=10
+ VTF=10
+ ITF=1)
Non é mai abbastanza...
Old 19th January 2008, 03:06 PM   #4
Thanks...
Old 19th January 2008, 08:48 PM   #5
hahfran is offline hahfran  Germany
So far I failed to import any new model into PSpice Student - freeware- model lib. Is that feature disabled in the freeware version or am I doing something wrong?
Thanks.
Btw considering distortion in amplifiers I prefer results obtained
at a university about human audition. It does not matter that much how the value of THD is what matters for a favorable overall impression is that the energy of the harmonics decrease in a particular mathematical series.
Old 20th January 2008, 12:05 PM   #6
You may want to give LTSpice a try - it is not disabled in any way, comes with a reasonable library of representative devices to get started, and it is fairly easy to add new device models simply by editing text files and adding models in standard Spice syntax.
Old 21st January 2008, 06:12 PM   #7
yes hardly any limitations with LT Spice.
Old 6th June 2010, 10:29 PM   #8
any news so far? i'm also searching for them..
thanks in advance
Old 7th June 2010, 02:10 AM   #9
still trying to find them, have a model for the APT-1 amplifier that's almost correct, except for the driver transistors... i would think with data sheets for these from Sanyo as recent as 2002, there should be a SPICE model for them
Old 7th June 2010, 10:50 AM   #10
same for me, a 3-stage Amp, i need them as the last lacking models.
never seen spice models on any DS seen until now..
just these basic info's on 2SA1011 (and nothing for 2SC2344)
" ap_pnp_2SA1011_19930601 Basic Description: PNP Transistor, Part number: 2SA1011, Key parameters: Is=1E-14 Bf=100 Tf=2.274E-08 "
found on PNP BJT Models - ADS 2008 Update 1 -Agilent EEsof Documentation Center (you already know..)
maybe some equivalent model ?
ATC drivers : models ermes Multi-Way 32 12th April 2009 11:31 AM
help with models. bogdan_borko Solid State 7 11th November 2006 02:19 PM
mje models? bogdan_borko Solid State 2 29th May 2006 11:37 PM
3f4 spice models needed Geek Tubes / Valves 1 23rd September 2005 07:39 AM
SPICE models for power amp output transistors needed... ergo Solid State 9 22nd March 2001 07:31 PM
Page generated in 0.08964 seconds (85.12% PHP - 14.88% MySQL) with 11 queries
