Old 24th February 2003, 09:00 PM   #1
Account Disabled
Default Adding a Sub output... sum the two inputs?
I am thinking of adding in a Sub output coming from my gainclone amplifier. Do I simply sum the L and R inputs with a simple opamp circuit?
Thanks,
-Paul
Old 24th February 2003, 09:22 PM   #2
Account Disabled
Or do I use an 'averager'?
Old 24th February 2003, 09:42 PM   #3
Default Use a mixer with Low pass filter
There are lots of Mixer designs on the net. They use summing into an opamp. Just add a low pass filter network on the front end of the mixer and voila you have your mono LOW only output for a Sub amp. For example (but not inluding the lowpass stuff)
http://litec.rpi.edu/LITEC_Tutorials...mp__Mixer.html
Old 24th February 2003, 09:53 PM   #4
Account Disabled
How does this look for a dipole sub equalization with the notch filter in it?
-Paul
Old 24th February 2003, 09:59 PM   #5
Helix is offline Helix  United Kingdom
Helix's Avatar
dont you reduce channel seperation with that?
Old 24th February 2003, 10:52 PM   #6
Default Why a notch?nt
Old 24th February 2003, 11:30 PM   #7
Account Disabled
I want to sum the channels so taht I get both L and R coming out of the single sub
The notch is because of the resonance that occours due to the 'D' from the front radiating area to the back. It will create a peak at 290 Hz with the enclosure that I am using.
-Paul
Old 25th February 2003, 12:14 AM   #8
Yes, what you need is a circuit that mixes both channels and puts a low pass filter to leave out everything that is not los frequency.
You do that before going into the power amp, of course, and you use just one amp as I think you know, and you do this crossover after the preamp or source output.
Why do you want to create a peak?
Carlos
Old 25th February 2003, 02:44 PM   #9
Exclamation Low pass pole at 100 hz or lower for Sub
Make the pole of your Low pass filter at 100 Hz or lower for a sub and then you will have no problems at 290 Hz. It will simply not be there. 290 Hz is not in the realm of sub-bass. Hell its not even bass really. It s low midrange. Kill it.
Old 25th February 2003, 04:51 PM   #10
Account Disabled
Yes, that is true, but this is only a 12dB/ octave low pass XO. If you cross out at 100Hz, that dosnt mean that everything above there is just gone. So if there is a 6dB peak at 290Hz, it will only be about 8 or 9 dB below reference due to the 12dB/octave 100hz XO.
That is why I need the notch.
-Paul
Replacing 5-pin DIN inputs on a Telefunken Radio? +weird speaker output? hageir Tubes / Valves 8 19th January 2008 07:59 PM
Adding secondary of output transformer into cathodes of output stage ? Eico ST-70 freddymac406 Tubes / Valves 3 21st April 2007 06:15 PM
Adding Wordclock inputs to source mlihl Digital Source 2 25th July 2006 02:36 AM
Adding Digital Inputs ?! Blue_Max Digital Source 3 25th January 2005 07:12 PM
Adding more inputs for my preamp bonsai171 Solid State 1 11th March 2004 10:59 PM
Copyright ©1999-2013 diyAudio
