So I have some HD580 headphones, need a amp - diyAudio
Old 24th February 2003, 09:54 PM   #1
Send a message via AIM to AJ Bertelson
Default So I have some HD580 headphones, need a amp
Well I am gonna migrate to headphones for a couple months and I would really like to build a amp for these things. I have some electronic experience and can read diagrams fairly well.
How much do amps usually cost to build? I am looking to keep it between 50-100
Old 24th February 2003, 10:50 PM   #2
nemestra's Avatar
Hi A J,
there isn't too much discussion of headphone amps at diyaudio - you might want to have a look at www.headwize.com which focusses specifically on headphones. Look in Library and then Projects for a large number of designs from the simple to the very complex.
James
Old 24th February 2003, 11:29 PM   #3
halojoy is offline halojoy  Sweden
On Hiatus
Originally posted by nemestra
Hi A J,
James
You should consider this "Zen-like headphone amp"
which is designed here at diyaudio,
in this thread:
ZEN-like headphones amp
It is built with MOSFET, those Nelson Pass uses.
tortello's amp
I know many of diyaudio.com members were interested in this amp.
They all wanted the details about it.
tortello's work even resulted in that he could publish his design
at the website nemestra provided above:
Headwize - the Home of Headphones Projects at the web.
They even have a special forum there, for all Homebuilders of Headp-amps.
Tortello's ZEN-like Headphones Amp
HeadWize - All projects Page
As you have a Sennheiser580, which is 300 ohm impedance (like Sennh.600),
you do not need quite as much current as 300mA.
Tortello's amp can be set to run as much.
Anyway you chose, you will find best projects at Headwize.
They are also very well described and also updated.
And you will also get support and answer to your questions
in this thread, as you go on.
Even tortello himself might drop by here.
/halo - has already dropped
ZEN-like headphones amp tortello Pass Labs 205 31st August 2016 09:07 PM
Headphones underwurlde Solid State 3 23rd August 2009 10:09 PM
for headphones Prune Pass Labs 4 14th September 2003 08:41 PM
Which headphones are the best Bull Everything Else 11 8th December 2002 10:17 PM
Headphones JazzFrac Everything Else 2 26th February 2001 06:13 AM
Copyright 1999-2017 diyAudio
