I'm wondering about preamp topology. Do they typically follow in the footsteps of their big brother - i.e. input stage, vas, output? There must be a lot of variation here, but I was just wondering if there is a typical method and if so, what is it.
Another question is about coupling. What makes for a better design: ac or dc coupling? gene |
#2 |
It's all down to how much gain you need. That comes down to how large the signal is from the source, and how much gain does the power amplifier have.
If the source is a typical CD player output of 2 Volts and the power amp requires only 1 Volt to reach max output then the pramp needs no gain at all. In which case the preamp is most likely to be a volume control feeding into a unity gain buffer. With the availability of unity-gain stable IC Op-Amps, Cathode followers and Source followers I would be surprised if many people made a complex three stage (input, voltage amp, output) preamp. Regarding coupling: theoretically dc should be superior, however think about current loops for a while and even dc coupled outputs are subject to some form of capacitor interaction via the power supply. Also dc coupling the output often requires servos which have their own issues. There may be merit in investigating a single voltage supply (as opposed to bi-polar) and use a correctly polarised coupling capacitor. Then again, I'm personally leaning towards transformers for output isolation and easy derivation of a balanced signal. |
#3 |
Doug Self has done a lot of work on preamps over the years, he has a website http://www.dself.dsl.pipex.com/ampins/ampins.htm
and I have his book Self on Audio which is terrific value, covers power amps and preamps, check it out. Ted |
#4 |
Just for a quick overview of preamp topologies, you might take a look at some of the schematics Nelson Pass has made available from his older commercial products. It's not an exhaustive list, by any means, but it may give you some ideas.
I must say that I am not a big fan of Douglas Self, but if you are of the opinion that heaps of negative feedback are what makes the sun rise in the morning, then your views may differ. Preamps vary widely in complexity. It can be as simple as a pot--this being the so-called "passive" preamp. (Be aware that this assumes that you don't need any gain. You may also have impedance matching problems.) Or it can be hideously complex. For an example, see the pictures on the Mark Levinson website showing preamps filled with twenty or thirty opamps. Then consider that even a hot-rod opamp will have at least ten or twenty transistors (and it's nothing for an opamp to have fifty or a hundred active devices), then multiply that by the number of opamps you see. Now that's a lot of complexity, even if you can't see all the individual pieces. Okay, so what to do? First, start by deciding on a realistic amount of gain. What do you really need to drive your system, given your source(s)? Some preamps are as low as 6dB. Some are in the mid-twenties. If you only listen to CD and your CD player has enough output to drive your amp as loud as you'll ever want to go, then you can get by with a simple buffer or a passive preamp. But start by determining how much gain you'll need. That will simplify your life greatly by ruling out certain topologies. Grey |
#5 |
I figure gain will be -100db < A < +10dB. That'll cover my volume needs plus being able to drive the amp to full output when input is low. After checking various manufacturers integrated amps, they spec sensitivity as low around 150mv (rms, I think)! My amp design has around 32 dB gain, then another 10db at the preamp brings this up to around 42 dB. Somehow, it sounds too high though.
I will check out the Nelson Pass schematics, thanks. |
#6 | |
Going back to your original question.........yes and no. Most hifi can be done unbalanced so a differential balanced input is only required if you want all your sources to be balanced. if your sources are unbalanced don't bother with differential input. Sources come in a wide variety of signal levels. Phono (MM) is a few mV and has to be treated specially with RIAA equalization to sound anything near right. If you don't need phono forget it. Next are MP3 type players that I think are a few tens of mV. Then cassette machines, MD and CDPs are 2V, but that is the maximum, the typical level may be nearer 200mV. You want to be able to drive your amp into clipping. You want to have the volume control at 50% most of the time. This probably adds up to between 10dB and 20dB gain. It is usual to put the gain before the pot. There is no need for a power output stage, you are driving a few feet of shielded cable to the power amp, the output device, opamp?, needs to handle capacitative loads OK, the OPA2134 is a nice dual IC for this application. Good Luck Ted |
#7 |
AC or DC coupling:
AC coupling requires small value input capacitors and larger value output capacitors. If the values are chosen with attention to the rolloff formula you pick a bandwidth much wider than audio needs, for example 5Hz and 50kHz. See this link for high and low pass filters which is what blocking capacitors are http://www.st-andrews.ac.uk/~www_pa/...hpass/hpf.html AC coupling is normal for simple designs, it is easy and failsafe. DC coupling is nice but not so easy to do. You get wider bandwidth, even though there isn't much audio below 40Hz. Unfortunately it only takes a few mV of DC offset on the volume pot for it to be scratchy when turned. You don't want there to be bangs when you plug the preamp into the poweramp, strains your drivers. You can chose single opamp ICs that have offset null pins and fit a trimmer pot to adjust the offset to zero, in theory. The single OPA134 will do that. Ted |
#8 |
It is more usual to put the active gain stage after the pot, it then serves as a driver for the line to the power amp. Note that any hum or noise present at the stage output will be constant at all volume settings.
#9 |
I am a no preamp convert... yes I do have an amp that actualy sounds better with a preamp, but every single other amp I have sounds better just passive.
Every stage you add to an amp adds is own distortion and signature to the sound... build a proper 3 stage amp and it is all the gain you need. I would only use a preamp on realy crappy amps.. does add some detail. Or some amps that needs realively large voltage swing on the input like some mosfet jobbies... |
#10 |
Food for thought, Nordic. I had thought of that, actually! And, I have to agree that less is more - probably, but I don't have the practical experience to back that statement up.
Although I'm designing a class-D amp, it doesn't really matter the type as long as the gain is large enough to be able to drive to full output. Toe problems remain: 1. volume control 2. variations in input types. So let's see - CD inputs are around 2Vrms, pretty hot. But, other line-input stuff may be as low as 150mV or so. That's a 10dB spread - give or take a couple of dB. How objectionable would it be to have a 10dB input gain select switch on the machine? Just a thought - since it brings those 2 extreme ranges in line with one another. Then, volume control - what a can of worms. I'm reluctant to use the likes of the CS3310 or TI or National equivalent programmable gain amp. However, I am puzzling over some programmable gain stages that may be fairly linear - jury is out on this one, though, I need to put more work into it. |
| Ayre V3 proto topology for preamp? | maxpou | Solid State | 4 | 20th March 2008 07:06 PM |
| topology for preamp, single ended or complimentary | maxpou | Solid State | 7 | 10th January 2008 10:41 AM |
| Oen loop preamp topology questions | bogdan_borko | Solid State | 0 | 3rd December 2006 07:02 PM |
| Preamp topology regarding placement of Pot | dine1967 | Chip Amps | 1 | 13th April 2006 07:23 PM |
| DIY preamp design - gain topology, IC vs. discrete, OPA627 vs. Zen... ? | dorkus | Pass Labs | 18 | 10th July 2001 05:26 AM |
| Page generated in 0.13066 seconds (84.13% PHP - 15.87% MySQL) with 11 queries |
