I have seen the IRF510 as head phone amp output.
Can I use IRF9530, which I have on hand, as output buffer in the similar configuration to Szekeres amp? Of course, I hope to use 30-100ma instead. Also, the input of IRF 9530 at 800pf is high, anyway to reduce the effect? tks and rgds William |
#2 |
If you use it in common drain mode (source follower) and keep the output impedance of the previous stage low, input capacitance of the MOSFET is not a problem.
#3 |
Tks, I think that is the only way. Will try it out and see how.
Also, I always wanted to try a simple amp. Nwo with the most recent op amp sounding very good, May be I can try to use Op amp driving a single IRF type as a simple power amp. If I use just IRF 9530, I will need an output cap, while if I use 9530/530, then I will not need an output cap. Not sure which way it will sound nicer. I just need a few solid watts. William Lee |
#4 |
In attachment is a schematic that I've successfully used to drive 50 Ohms headphones. If you have higher Z headphones (300 or 600 Ohms) you can raise the power supply voltage and lower the bias current (by upping the R4 value). That will save some heat dissipation.
#5 | |
#6 |
Tks for the diagram! I am yet to try the sound of regulator to replace 7815/7915. I suspect 317/337 type is better, but I wud like to try a discreate type with max 2 transistors...
btw I am tweaking my pre amp now and playing with some op amps, I find that THS 4012 sounded best, better then 4032 and OP637. best rgds William Lee |
#7 |
hi Juma,
I wanted to try using op amp driving the IRF9530 MosFet, and run the output stage with +/- 15V. To modify your circuit, Can I just have R2 100K that connect the R1 220 ohm input R to the ground, but eliminating the R3 22K. Also, direct couple the R1 to the output of the Op amp. Do you use the TL431 as Zener here as I am not familiar with this device, is this a Zener or triac? how about using an LED to replace? Tks and best rgds William |
#8 | |
TL431 is shunt voltage regulator, but I use it here as voltage reference (2.5 V) for constant current source (CCS). You can use LED, Zener or any other means to make your favorite CCS. This circuit tends to sound better with more current flowing through MOSFET, but it's up to you to find a balance that suits your headphones the best. |
#9 |
Tks Juma, seem the current thru the CCS is about 13 ma, so beter use 2 LED in parallel I think or I iwll play wiht it. Even 2 battery may be good!
best rgds William |
#10 | |
No William, the current through BD140 is 1.8 V / 6.8 Ohms = 265 mA. That's what I found good for my headphones (Sennheiser HD555). I don't know what's your load for this buffer amp, but even with the very light load you should bias MOSFET with at least 50 mA. Anyway, this is very simple circuit and you should experiment a little - that's how you'll find what suits your needs the best. |
| current buffer for cd output | maxpou | Digital Source | 0 | 14th February 2008 04:14 PM |
| PGA2310 output buffer? | Freddie | Solid State | 26 | 13th February 2008 10:09 PM |
| Berning output buffer | Bill*B | Tubes / Valves | 10 | 16th October 2005 03:12 AM |
| buffer with balanced output | udip | Solid State | 22 | 23rd February 2005 06:53 AM |
| Page generated in 0.44624 seconds (95.48% PHP - 4.52% MySQL) with 11 queries |
