I have searched these forums and the web, and I have a general "idea" as to how a grounded bridge amplifier works (I understand the Crown Audio white paper regarding the grounded bridge).
According to Dynacord (I.E. the P3000), the output stage is a "Class H 3 stage grounded bridge" topology. What exactly does this mean, as compared to a regular "grounded bridge" topology? I looked for any white papers from Dynacord, but I could not find any regarding this proprietary output stage. |
#2 |
In Class-H amps with Grounded Bridge Topology we have 3 choices to choose for:
1. Monorail Switching like in QSC PL6.0II amp. Switching from Lower Tier to Higher[Tier might ranges from 2 to 4 steps] is made using only one side of rail, but excitation takes place for both polarity of signals. 2. Series-Parallel technique is like configuring the 2 isolated supply voltage sources in Series for greater voltage swing and for low current te voltage sources are paralleled, its a Pseudo Class-H. 3. Regular Class-H switching which is used by Dynacord intheir POWER H series, it uses switching for both polarity of signals along with individual rail switch for Each Quadrant of the bridge. Monorail is more advantageous of all. Its a low cost, low part count & high reliability topology. For single step Class-G is best way in monorail switching, for more steps Class-H wins.
#3 |
After reading the Crown white paper on the grounded bridge topology again,
There are two "pairs" of "output devices" connected to the load, one pair (let's say an NPN and a PNP transistor) that drives the speaker itself, and the other pair drives the "ground" so as to adjust the floating voltage power supply to the correct level. Can I say that the power dissipated in the output stage is twice that of a regular, conventional output stage? I see that in a grounded bridge configuration, the output current will always flow through two output devices, either through the load driving NPN and the ground driving PNP, or through the load driving PNP and the ground driving NPN. Am I correct in saying this? |
#4 |
The power dissipated in a grounded bridge is not any worse than any other "bridge". It's only slightly more than a single-ended topology. It just trades voltage for current, and has half the voltage on the transistors. "Grounded" bridge is advantageous in that two channels are again "bridgeable" because the supplies are independent.
If you're going to switch all four quadrants of a grounded bridge you may as well just put both secondaries in series, cascode the output stage and just switch like a normal amp. |
#5 |
Candidates for the Darwin Award should not read this author. |
#6 |
DJK:
Can you tell us more? I started a similar topic: Can some one explain me this amp? Can some one explain me this amp? There was not much reaction allthough it gave me a bit of insight. Maybe here there is more to learn. thanks, Tarzan |
#7 |
djk: thank you for the post - that is a very good pic showing the concept
I still have a question: Maybe I'm just not "seeing" it, but for the class A amplifier, why is it only +/- 27V? Wouldn't this cause clipping if the other side of the bridge is driving the speaker at, say, +50V? I can see how the right side is a rail switching amplifier --> Does this mean that the +/- 27V, +/- 55V, and +/- 80V rails are sharing a common "floating" ground? |
#8 |
This is a simple basic GBR amp topology with rails switching could be a Linear modulation or Saturated Switch in other words Class-G or Class-H.
#9 |
The Crown VZ5000 and vz3600 use the saturated switch, National Semiconductor was issued a patent on the linear modulated method.
Using a PWM top rail modulated by the audio is the basis of the old Sunfire subwoofer amp (and the BASH amps too). Sandman proposed a bridge amp scheme circa 1971 that has a small high quality amp (A2) controling a larger quick-and-dirty one (A1). The first commercial version of the asymetric bridge amp I saw was the old Yamaha B2X, the class A side ran on ±6V, the class AB side on ±63V. The thumbnail drawing I posted of the asymetric class A design was from BSS, a pro sound amplifier.
#10 |
One question that I have failed to ask, and I think it would help in understanding the grounded bridge concept:
I am assuming that, in most grounded bridge amplifiers, the amp still resembles a basic "three stage" conventional amplifier (input differential pair, VAS, and then the grounded bridge output stage). ==> What supply voltages are needed in the first and second stages? For instance, if a grounded bridge amp has a maximum voltage supply of 75V on its output devices (floating, so the load could either be +75V or -75V maximum), then does this mean that the input stage and VAS stage should be powered from a conventional +/- 75V supply to prevent clipping? ------------------- ==> Sandman proposed a bridge amp scheme circa 1971 that has a small high quality amp (A2) controlling a larger quick-and-dirty one (A1). Yes, I *think* that this was the beginning of the SMALA amp (switch-mode amplifier linearly assisted), where the class-D amplifier (high efficiency, not so great distortion) supplies the majority of the current, and the "linear assistance" class A (or AB) amplifier provides the small correction current to smooth out the distortion. These currents add before reaching the load, and theoretically, the result is a high efficiency, better linearity amp. Correct me if I am wrong in my assertion here. |
| What makes an amplifier "bright", "warm", or "neutral"? | JohnS | Solid State | 51 | 13th December 2009 07:42 PM |
| Line stage preamp, based on SY's "Heretical Unity gain line stage" | Danko | Tubes / Valves | 23 | 18th July 2005 05:07 AM |
| Effect of cross-coupled "local" FB on plate load of previous stage | ray_moth | Tubes / Valves | 23 | 27th April 2005 09:55 AM |
| Scavenging transformers to "bridge" | Paulr | Solid State | 0 | 7th August 2003 11:29 AM |
| How To "Bridge" A Stereo Amp to Just One Channel | kelticwizard | Subwoofers | 17 | 20th September 2001 05:27 AM |
| Page generated in 0.12730 seconds (78.37% PHP - 21.63% MySQL) with 11 queries |
