48 VDC/10 A power supply looking for an Amp design - Page 2 - diyAudio
Old 15th January 2008, 06:42 PM   #11
and another...
Jack of all Trades, Master of None
Searching for Sonic Nirvana...
Old 15th January 2008, 06:45 PM   #12
Default Last one I promise....
Thank you for bearing with me as I figure out the idiosyncrasies of this forum. ...
Old 15th January 2008, 08:31 PM   #13
Nico Ras's Avatar
Default Re: Last one I promise....
How low is the low end <100 Hz?
Old 15th January 2008, 08:34 PM   #14
Nico Ras's Avatar
If <100 Hz, there is no directivity regarding stereo. I would connect the two woofers is series and use two KSA50's biased for class AB and bridged.
Old 15th January 2008, 08:40 PM   #15
ekaerin is offline ekaerin  Sweden
ekaerin's Avatar
....If you have the rackspace left.... the supply is an excellent mate as
an outboard PSU for a single supply, or as someone mentioned a bridged type, poweramp.
To bad you can't see the X-former when the unit gets thrown into the rack.
/ Mattias
Old 15th January 2008, 09:04 PM   #16
Nico Ras's Avatar
Simple workable example.
Old 16th January 2008, 11:39 AM   #17
It might be worth examining the secondary of the transformer in this power supply, and seeing if it only has the one output winding, or two in parallel. If it has two in parallel, you could get 48V bipolar supply - at 5A per rail. As there are two capacitors (presumably in parallel) you could use those too.
Power Supply Design Defbrett Tubes / Valves 28 10th October 2009 12:54 AM
I would like to design a power supply Kramerguy Power Supplies 9 14th January 2009 06:50 PM
need help with a power supply design lochness Power Supplies 1 31st October 2007 06:12 PM
Power Supply Design whitelabrat Power Supplies 8 29th May 2007 04:14 PM
Power supply design LeakSt20 Parts 0 16th August 2005 04:06 PM
Copyright 1999-2017 diyAudio
