Old 14th January 2008, 06:05 PM   #1
Default ## circuit for Transistor testing ?
Hi guy´s,
has anyone a simple circuit with there i can test high power transistors as 2SC2922 and 2SA 1216.
For example a small circuit with LM317 or a L200 as power supply in that i can build in the 2922 or/and 1216 as current driver to bring them to there SOA (so 9 Ampere current) ?
Or a other simple Circuit with there i can test this Transistor up to the SOA border ?
greetings
Dirk
Old 14th January 2008, 06:09 PM   #2
test at what temperature? heatsink or transistor case or junction temperature monitoring?
Beyond or within the voltage of the second breakdown knee?
Continuous (DC), or 1second, 100mS or 10mS single shot?
regards Andrew T.
Old 14th January 2008, 06:24 PM   #3
complete DC without other Signals.
The transistor has on Emitter a resistor with 8,4 or 2 ohm with 100 to 200 watt. The transistor are passiv and activ cooled. See pic.
I have a power supply with 2*34 Volt with 9.5 Ampere and i will bring the Transistor near the SAO and will see that hold his data what stand in the datasheet.
Dirk
Old 14th January 2008, 06:28 PM   #4
Default Re: ## circuit for Transistor testing ?
Originally posted by small_boy
Hi guy´s,
greetings
Dirk
Errr! No!
That is very difficult and requires very fast short pulses with low duty-cycle (<1%) at very high power.
Otherwise the transistor will be zapped in milliseconds, even if decently heatsinked.
Industrial testers use an inductive load flyback circuit to move the DUT from a saturated collector current up to a secondary breakdown.
Once, and for only about 300uS.
SOA is a calculated curve from various parameters (thermal, Imax etc) and cannot be "measured" directly.
Old 14th January 2008, 06:49 PM   #5
Tarzan is offline Tarzan  Belgium
Tarzan's Avatar
Once up on in time (1975?) there was an application note of RCA; I can't recall wich one.
It described a test setup for a transistor tester WITH the possibility to test the SOA of a transistor.
If my memory is correct it could go up to 300V and a huge amount of amps.
It checked the temp as well, allthough I'm not 100% sure.
I rather like to find that application note again.
It was a bit expensive for me at that time to build but I can now.
If only I had that AN...
Maybe one of the older members?
(look who's calling others "older"...)
Zilog
Old 14th January 2008, 07:02 PM   #6
@cliff
Why is then in the datasheet from Sanken for SOA one line for DC and one for Pulse ?
@zilog
I´m old (39 year at begin of February ;-)) but on 1975 i was 6 and have don´t interest for Electronics
Dirk
Old 14th January 2008, 07:23 PM   #7
Tarzan's Avatar
Oh jee small_boy ,
Im 54 now, heading for 55.
If only I kept all my docs the time I as young.
You can never tell the way your life go's.
So if I may give some advice:
Never ever trow away your data books, magazines and other stuff.
One day they will come in handy.
So to the real "old" guys; look around if maybe you have that AN from RCA.
Cheers.
Zilog
Old 14th January 2008, 08:04 PM   #8
@cliff
@zilog
Dirk
Yes, I lost 30 years worth of data books and notes in a fire
Confusing isn't it, small-boy ??
That curve says "natural cooling without heatsink", but the first break-point is 20A Ic at 10v VCE.
That is 200W.
Even with a fan cooled massive heatsink that is not real!
What do you want to TEST for SOA? If it doesn't meet SOA it dies. Period. No way back.
It is a design-aid curve.
Old 14th January 2008, 08:45 PM   #9
@Tarzan :
Oh jee small_boy ,
ok ok, then i´am a young boy
@cliff :
oh thats ****.
Ok, i will test this transistors 2SC2922 with 8-9 ampere, over 1-2 hours and go near to the 200 watt Ptot to see that it don´t burn.
This is the only way to see that these transistors hold, what the datasheet says.
Because this are not from Sanken, there are from ISCSemi, and in the thread :
### Counterfeit transistors
you can read what problem i have.
A few told me, that this transistors are fakes, other that the trans from ISCSemi are ok. But now i will test it with power and look that there hold what the datasheet says.
What can i do to test this transistors and how ?
Dirk
Old 14th January 2008, 09:27 PM   #10
I do sympathise and you really do have a problem.
However, in my long experience, trying to test at DC is a complete waste of time. But I am not always right.
What are you going to do if they fail? The supplier will only accept THEIR test methods and not yours.
Have a look at:
SOA
particulary at the inductive test circuits.
As I said earlier, SOA curves are design aids. If you are having reliability issues and failures my first step would be to search for devices with 50% to 100% better SOA specs.
I don't think I can help more ....
Transistor testing question woody Solid State 0 10th October 2008 04:08 AM
Setting Up a Circuit for Testing Sherman Tubes / Valves 22 27th November 2005 10:11 AM
preamps, transistor testing, power amplifier yamaha priscared Solid State 20 1st October 2004 08:31 PM
Testing capacitors in circuit. Tony D. Parts 1 22nd September 2002 12:14 PM
Page generated in 0.11778 seconds (80.90% PHP - 19.10% MySQL) with 11 queries
