Old 15th January 2008, 01:56 AM   #11
Eva is offline Eva  Spain
Eva's Avatar
Send a message via MSN to Eva
Those 200W are *real*. This transistor comes in the unusual MT-200 package and is rated for 200W continuous at Tcase=25șC, 160W at 50șC, 120W at 75șC, 80W at 100șC and 40W at 125șC.
DC SOA may be tested as long as derating due to increased temperature is taken into account. Peltier cells may come handy to keep the case at 25șC.
I use to feel like the small child in The Emperor's New Clothes tale
Old 15th January 2008, 10:10 AM   #12
note that Eva's post shows the maximum powers, below the second breakdown voltage, for case temperatures @ or above 25degC.
For Tc=100degC the maximum continuous power is just 80W (2Adc @ 40Vce). This is the temperature de-rated SOA limit for a 200W, 150degC device.
Try running the device at this temperature and power dissipation and see if it survives. Remeasure hFE at various currents to see if there is any deterioration.
Now run the device a bit over 100degC at the same power dissipation (2A @ 40Vce) and see how long it lasts. Tc=110degC may last a few hours. Tc=120degC may last just a few minutes.
The results will be instructive to us all.
regards Andrew T.
Old 15th January 2008, 10:22 AM   #13
Tarzan is offline Tarzan  Belgium
Tarzan's Avatar
I still try to convince the "older" readers to have a look at their huge piles of docs and application notes.
The test setup as described by RCA was a NON Destructive (!) way of finding the soa of a DUT (Device under test)
This would be the ultime testaparatus to weed out all fake transistors from your stock and to check the new incoming.
There must be at least one copy laying around...
A link to an RCA archive?
An ex RCA buddy?
Zilog
Old 15th January 2008, 01:00 PM   #14
syn08 is offline syn08  Canada
Not really required. Take a look at this: http://www.fairchildsemi.com/an/AN/AN-7516.pdf It describes in detail a method of SOA testing without even using a heatsink. This method was originally developed by Intersil, this is the old orginal: http://www.nalanda.nitc.ac.in/indust...sil/an9409.pdf Don't know if there was any similar approach before 1994...
Unfortunately, a true SOA testing bench is not something that can be easily home brewed. As others mentioned, it requires a constant (high) power pulse generator which a complex piece of equipment by itself.
Old 15th January 2008, 02:45 PM   #15
wg_ski is offline wg_ski  United States
Peltier junction? Even at .1C/W case to sink (and that's being optimistic) that's 20 degrees of rise. Try immersing the heat sink in an icewater bath - that will get Tc down close to 25. Testing at elevated temperatures doesn't tell you as much - remember the old Motorola app notes which specifically state "At high case temperatures, thermal limitations will reduce the power that can be handled to less than the limitations imposed by second breakdown".
With the heat sink on ice, the DUT should be able to take rated power (at the second breakdown point) for 1 second on, 10 to 20 seconds off.
Old 16th January 2008, 03:44 PM   #16
Tarzan's Avatar
I went through my docs and found a RCA booklet with a list of Application Notes.
Here it is.
AN-6145 A Test Set for Nondestructive Safe-Area Measurements Under High-Voltage, High-Current Conditions
Any body?
Tarzan
RCA Power-Device Application Notes
General Power Applications
AN-3697 Triac Power-Control
AN-4537 Thyristor Control of Incandescent Traffic-Signal Lamps
AN-6054 Triac Power Controls for Three-Phase Systems
AN-6096 Solid-State Approaches to Cooking-Range Control
AN-6141 Power Switching Using Solid-State Relays:
AN-6286 Latching Gate-Trigger Circuits Using Thyristors for Machine Control Applications
AN-6452 A New Practical Fuse-Thyristor Coordination Method
ICAN-6182 Features and Applications of RCA Integrated Circuit-
Zero Volt Switches (CA3058, CA3059, CA3079)
Device Characteristics'
AN-4242 A Review of Thyristor Characteristics and Applications
AN-6215 Interpretation of Voltage Ratings for Transistors
AN-6272 Characteristics of RCA Monolithic Power Darlingtons
AN-6438 Surge Capability of SCR's, Triacs, and Rectifiers
AN-6456 Characteristics and Applications of RCA Fast-Switching ASCR's
AN-6624 Voltage Limitations of Power Transistors
AN-6671 Characteristics and Turn-Off Circuit Considerations for RCA GTO SCR's
AN-6687 Latching Voltage and Current in Thyristors
AN-6689 Circuit-Commutated Turn-off Time of Thyristors
Handling and Operating Conditions
1CE-402 Operating Considerations for RCA Solid State Devices
AN-4124 Handling and Mounting of RCA Molded-Plastic Transistors and Thyristors
Test/Ratings
AN-4573 Testing for Forward-Bias Second Breakdown in Power Transistors
AN-4612 Thermal-Cycling Rating System for Silicon Power Transistors
AN-4745 Analysis and Design of Snubber Networks for dv/dt Suppression in Thyristor Circuits
AN-4783 Thermal-Cycling Ratings of Power Transistors
AN-6163 Quantitative Measurement of Thermal-Cycling Capability of Silicon Power Transistors
AN-6281 Accurate Measurement of Sustaining Voltage of Power Transistors A Pulsed-Breakdown Test Set
AN-6330 A Safe-Area Rating System for Power Inverters Handling Capacitive and Inductive Loads
AN-6425 Automatic Analyzer for Determining Safe Operating Area of Power Transistors
AN-6800 A Test Set for Measuring hfe and fy as a Function of Collector Current
Old 16th January 2008, 10:19 PM   #17
would be nice if this still would have somebody !
Dirk
Old 31st January 2008, 07:52 PM   #18
Tarzan's Avatar
AN 6145 is available (allmost)
I have to scan the pages and make them available.
Test setup for transistors:
Current range: 0.2 .. 20 Amps
Voltage range: 10 .. 350 Volts
Pulse width: 10 microseconds .. 2 seconds
Very impressive...
As the name of the doc is:
A test Set for Nondestructive Safe-Area Measurements under High-Voltage, High-Current Conditions.
So a bit of patience and it will be here.
Zilog
Old 1st February 2008, 12:30 AM   #19
no problem, i can wait and the ISCsemi transis dont run away.
Dirk
Old 6th February 2008, 07:33 AM   #20
Tarzan's Avatar
Hey small_boy,
Got the AN scanned and convert each page (8) in to a pdf file.
Sorry to tell you they are HUGE in size.
An RAR file with all 8 of them is 22MB.
Each file in turn about 4.5 MB.
Contact me direct so that I can send them to you.
It needs however a seperate 300V psu.
This instrument could be a very interesting project here.
It will surely have it's use with all the counterfeit power transistors around that can blow up your expensive repair or project.
Tarzan
Transistor testing question woody Solid State 0 10th October 2008 04:08 AM
Setting Up a Circuit for Testing Sherman Tubes / Valves 22 27th November 2005 10:11 AM
preamps, transistor testing, power amplifier yamaha priscared Solid State 20 1st October 2004 08:31 PM
Testing capacitors in circuit. Tony D. Parts 1 22nd September 2002 12:14 PM
Page generated in 0.13241 seconds (83.02% PHP - 16.98% MySQL) with 11 queries
