I just got this completed board off ebay. $15 with shipping from China. Wondering if it looks familiar to anyone. Also curious if the design is any good. I'm hoping to use it as an output buffer for my cd player.
#2 |
pic of board. each is 2 channel
#3 |
Hi homemade,
that is cascoded complementary buffer, well known/used and nice performing circuit. Usually, it's made with 2sk170/2sj74. 2sk246/2sj103 are a bit different jfets (less transconductance). Try it and tell us how does it sound |
#4 |
Magneto the Gravity Man
Hi.
I've seen this advertised too. Have you tried it yet ?? Andy |
#5 | |
Is this buffer can work on Ucc=+/-9V or need something changed? What needs to change the schematic to its input resistance is 1Mohm? thank you |
#6 | ||
Take a look at the input of the F4 amplifier buffer in the Pass Labs forum, also have a look at the DCB1 buffer as an alternative. Last edited by Itsmee; 26th April 2012 at 09:32 PM. |
#7 | |||
#8 |
Strange cascode.
In Juma's circuit, the base voltage of each common base bipolars is half way between the output and the rail. In Homemade's circuit, R2 and R7 are in series and not connected to the output. Using this connection, a fet associated with its bipolar do make not cascode at all. |
#9 |
Post 1 is a true cascode. Post 3 results in a constant Vds for the fets, sort of like a bootstrap. I think for a common drain circuit (source follower), constant Vds may be more advantageous.
All the trouble I've ever been in started out as fun...... |
| Does this FET buffer circuit look familiar? | homemade | Parts | 1 | 9th January 2008 11:19 PM |
| Use of PNP transistors instead of NPN in buffer circuit. | TB | Chip Amps | 13 | 8th October 2007 06:58 AM |
| anyone familiar with the 211/vt4c circuit from Fi Primer? | jarthel | Tubes / Valves | 2 | 29th May 2007 03:52 PM |
| Can anyone recommend a good buffer circuit | primalsea | Tubes / Valves | 9 | 23rd November 2004 09:58 PM |
| Linn LK-2(60) One Channel has Failed. Anyone familiar with this circuit design? | dtm1962 | Solid State | 0 | 11th April 2004 12:41 AM |
| Page generated in 0.11856 seconds (79.76% PHP - 20.24% MySQL) with 11 queries |
