#41 | |
Dirk |
#42 |
Hi small_boy
In Germany don’t know. But I strongly recommend you http://www.profusionplc.com/pro/gex/...?imanuf=sanken in UK.
Yo no creo en brujas pero que las hay... las hay (Cervantes) |
#43 |
OK, have mail from ISCSemi !
The 2SC2922 with scratch are realy from ISCSemi. OK, less one problem. The service of ISCSemi is very good and fast. I was real astonished. Miss Lynn from ISC has send me per mail the Datasheets for the 1216 and 2922. because probs with Homepage of ISC. When i look in the datasheet i mean that the data are same as the data from Sanken´s 2S. Or not ? Datasheet of 2922 : ![]() ![]() ![]() and for 1216 as pdf attached. Big different between Sanken and ISC ? Dirk |
#44 |
I use to feel like the small child in The Emperor's New Clothes tale |
#45 |
the Sanken graphs have been relabeled but otherwise the data seems to be identical.
regards Andrew T. |
#46 |
#47 |
Hello Small Boy (again) and all others,
Got the AN scanned and convert each page (8) in to a pdf file. Sorry to tell you they are HUGE in size. An RAR file with all 8 of them is 22MB. Each file in turn about 4.5 MB. Contact me direct so that I can send them to you. It needs however a seperate 300V psu. This instrument could be a very interesting project. It will surely have it's use with all the counterfeit power transistors around that can blow up your expensive repair or project. Cheers, Tarzan |
#48 |
Here are the links for download:
Page 1 to 8 http://www.yuntaa.com/FileManager/Do...40A8C003022DED http://www.yuntaa.com/FileManager/Do...40A8C003022DEB http://www.yuntaa.com/FileManager/Do...40A8C00302311F http://www.yuntaa.com/FileManager/Do...40A8C003022DED http://www.yuntaa.com/FileManager/Do...40A8C003022F96 http://www.yuntaa.com/FileManager/Do...40A8C003022DEB http://www.yuntaa.com/FileManager/Do...40A8C0030230C4 http://www.yuntaa.com/FileManager/Do...40A8C003022DED Sorry for the mess. |
#49 | |
Magneto the Gravity Man
I, for one, would be interested. Andy |
#50 | |
Thx Tarzan !
| Marantz 2600 Receiver...counterfeit (or remarked) transistors? | EchoWars | Solid State | 2 | 29th May 2007 08:59 PM |
| Are these transistors counterfeit? | geaugafletcher | Parts | 4 | 18th January 2007 03:36 PM |
| Counterfeit? | Amblifier | Solid State | 10 | 24th September 2005 06:07 PM |
| Counterfeit transistors??? | peter5 | Solid State | 1 | 20th February 2002 07:34 AM |
| Page generated in 0.10527 seconds (81.45% PHP - 18.55% MySQL) with 11 queries |
