1400w amp in 4 ohms
1400w amp in 4 ohms
Closed Thread
Old 14th January 2008, 12:58 PM   #11
dell is offline dell  Philippines
Default amp
What about using the sample applications of LM4702? Is worth trying?
Old 14th January 2008, 01:08 PM   #12
Workhorse is offline Workhorse
Workhorse's Avatar
http://www.diyaudio.com/forums/showt...84#post1400084
Check this
Old 11th June 2009, 05:45 PM   #13
doug79me is offline doug79me  Kenya
Default esp project 117
pls can someone assist me in the biasing of this circuit coz tome its working but does the mpsa 42 and mje340,350 on the biase side have to overheat any assistance willbe appreciated
Old 11th June 2009, 05:45 PM   #14
Default esp 117
there are 2 different cct of p117 one has 680ohms resistorwhile the other has 2.2 kohms on the bd681 transitor pls help for a genuine one
Old 12th June 2009, 01:24 AM   #15
unclejed613 is offline unclejed613  United States
unclejed613's Avatar
esp's website has a builder's forum for this amp. several builders have made them successfully
Vintage Audio and Pro-Audio repair ampz(removethis)@sohonet.net
spammer trap: spammers must die
Old 30th January 2013, 02:12 PM   #16
nithinmukund is offline nithinmukund
1.5kw any chenge this circute for better qality?
Old 30th January 2013, 03:22 PM   #17
Telstar is offline Telstar  Italy
Resurrection? Isn't it a bit early?
"The response of the inner ear extends to at least 200khz" Dr W. Tempest
Old 25th May 2013, 09:51 AM   #18
lm324 is offline lm324  Brazil
Originally Posted by djk View Post
If you actually want a working amp, don't even think about the ESP design.
What I would so would be to build the Super Leach and go from two output sets per side to six output sets per side. With the proper transistors and a couple of other minor changes it will run from ±135V.
The difference of why this amp will work, and the ESP will not work is the series connected output stage.
http://users.ece.gatech.edu/~mleach/...mp/circuit.pdf
Hi DJK,
What "other minor changes" ?
Thanks,
Roger
Old 25th May 2013, 09:56 AM   #19
R.I.P.
Can we ask that this Thread be closed?
regards Andrew T.
Closed Thread
1400w amp in 4 ohmsHide this!Advertise here!
ISOBARIC 16 ohms load powered by 8 ohms Amp eddi0 Subwoofers 24 21st October 2006 03:29 PM
Speakers: 8 ohms vs. 16 ohms KT Multi-Way 2 14th April 2006 05:06 PM
4 ohms vs 8 ohms carieux22 Everything Else 5 16th July 2005 12:53 AM
where to buy 16 ohms l-pad ger56 Multi-Way 0 11th October 2004 11:11 PM
zen on 4 ohms trancy Pass Labs 5 29th February 2004 06:54 PM
