About PCB layout - Page 2 - diyAudio
Old 10th January 2008, 05:11 PM   #11
CBS240 is offline CBS240  United States
CBS240's Avatar
Hi Gaetan
A square wave, regardless of frequency, will have the same slew, and contain odd harmonics toward infinity until your amp limits the slew rate by filtering out those frequencies above Fo. The 'faster' frequency just allows you to zoom in on the X-axis, so to speak. If 30KHz looks terrible, then the leading edges of the 1KHz also looks terrible, just you can't see it with the larger X-axis scale. Square wave is usually used to test the amp's speed and stability when driving a capacitive load. A pure capacitive load should cause some overshoot, the question is to what degree?
You might post a picture of the waveform(s).
The resistor in the Zobel, series to the cap, may or may not fry but it is a capacitive load and should be removed for the square wave tests.
All the trouble I've ever been in started out as fun......
Old 10th January 2008, 05:58 PM   #12
wg_ski is offline wg_ski  United States
The lower frequency square wave should be used during checkout because if there is oscillation or cross conduction induced, it will happen less times per second and be less likely to cause a fire. The X axis is easily changed on the scope. If the amp is functioning correctly 30KHz won't do anything other than heat up the zobel at high levels. Remove it? With a resistive load yes, but not with a loudspeaker as the amp may (or may not) become unstable without a resistive high frequency load (which is what the zobel is).
Yes, there are things you won't find. Like those little self-extinguishing bursts of oscillation on the PNP side, right when the NPN physically cuts off - right about -4V peak. Just about any low frequency signal, including music, will find it - if it's at exactly the right level. Square wave can go right through it so a sine is better. These oscillation modes are non-destructive and you can use the amp, and take your time tracking them down. I've never had one due to a PCB parasitic issue, but I've had them with large output stages mounted off-board and with a cascode output stage with no base stoppers (note to self - you CAN'T do that!!!).
Old 10th January 2008, 06:09 PM   #13
Jan Dupont's Avatar
Send a message via MSN to Jan Dupont
Gaetan;
Thanks I would appreciate to have the schematic for my website
Free Schematic and Service Manual downloads www.audio-circuit.dk, Spare time company (just for fun): www.dupont-audio.com
Old 10th January 2008, 10:37 PM   #14
Hello Jan
I've send it to you by email.
Bye
Gaetan
Old 11th January 2008, 04:11 AM   #15
Jan Dupont's Avatar
Received.
Thanks a lot, gaetan
Eagle vs. Sprint-Layout for PCB design/layout hollowman Parts 11 12th January 2014 09:01 PM
Whose layout is this? Ulew Chip Amps 9 14th December 2008 02:33 PM
pcb layout jamesrnz Power Supplies 0 9th March 2008 12:42 AM
help for a PCB layout pencoat Parts 0 4th October 2006 01:52 AM
Possible GC layout? lazyfly Chip Amps 4 22nd August 2004 04:28 PM
Copyright 1999-2017 diyAudio
