Old 4th January 2008, 11:54 AM   #1
Skorpio is offline Skorpio  Denmark
Default Passive preamp?
I have noticed tha the transformer based passive preamps have been popular and are getting good reviews.
Also som of the potentiometer based units are getting good reviews, but they have traditionally been claimed for reducing dynamics?
I wonder where the biggest limitations with passive potentiometers are?
-Source driving cable and potentiometer?
-Potmeter driving cable and input impedance of power amplifier
-Both
It will all depend on the different impedance levels off cource, but what potentiometer values are recomended?
For driving 10K input?
For driving 200K input?
Why i trafos better?
Old 4th January 2008, 12:16 PM   #2
Nordic is offline Nordic  South Africa
Nordic's Avatar
As far as I know they aren't "better" jsut gives good galvanic isolation... cheap ones are normally bandwidth limited to one extent or another....
Old 4th January 2008, 12:30 PM   #3
Calvin is offline Calvin  Germany
Calvin's Avatar
transformers are imo not better than resistive solutions, but vice virsa, when done properly. One big drawback is that good transformers are quite expensive and just allow for a couple of volume steps. Nice thing is that there will be no galvanic coupling of devices.
Simple potentiometers are not the right stuff to use, because of the high and changing output impedance. Typical sources are able to drive loads down to 1kOhms and even below. So You don´t need the constant input impedance the potentimeter shows. A changing input resistance of a resistive network is therefore no problem as long as its value is high enough. What You need is a rather lowish and constant value of the output impedance. Therefore You need other networks with at least 3 resistors per step.
Such a network doesn´t leave anything to wish for sonically and outperforms transformer-solutions, as well as any active solution.
jauu
Calvin
Old 4th January 2008, 01:18 PM   #4
Thank you for the replies.....
How would a network like that be made?
You mean something like a voltage divider with a low value resistor to ground?
Old 4th January 2008, 06:42 PM   #5
hahfran is offline hahfran  Germany
This is an "almost passive" preamp.
The attenuator is configured such that input impedance is constant 10 kOhms for all attenuations and output impedance is constant 3 kOhm for all attenuations except 0 dB.
It allows for attenuation in 1.25 dB steps.
Relays are encapsulated nitrogen-filled Teledyne. The amp is in use for about 20 years the relays are still doing perfectly well.
The bipolar chip opamp was later replaced by a discrete Aikido replica with 2N5196 matched n channel JFET pair and BUZ22 Mosfet.
It can drive 3 volts rms into 1 kOhm without distortion.
Dieter F.
Old 21st May 2008, 04:07 PM   #6
Tolu is offline Tolu  Germany
Tolu's Avatar
Hi Dieter
do you have some more informations and more detailed pics of your preamp?
Old 22nd May 2008, 07:50 AM   #7
Bgt is offline Bgt  Netherlands
Calvin, well said.
I've build active preamps with LM4562 chips but really...there is nothing like a passive preamp with decent stepper att.'s.
Dynamics are absolutely no problem with a passive. The so called "increased dynamics" with an active is mostly due to some kind of more bass and is a kind of distortion whereas a passive is so utterly clean that it looks like it is less dynamic.
Use 10k steppers with low impedance dc coupled output sources and reasonably high impedance dc coupled power amps. like the f.i. the UCD's.
Kind regards,
Bert
Old 22nd May 2008, 09:31 AM   #8
if you are going to passive pot attenuation then start with a low source impedance.
Let's start from your source:
Rs~=100r,
Pot ~=20Times Rs, gives pot~=2k.
Can your source drive 2k0 to normal signal levels?
Can the source drive the 2k0 to somewhere between +12dB to +20dB above normal signal levels?
If yes to both, then proceed.
The maximum output impedance of the pot is [Rs+potvalue]/4=[100+2000]/4=525r
The Zin of the next stage should be ~=20Times maximum pot output impedance. i.e Zin~=20*525~=10k.
If your source impedance is different from 100r then scale all the values accordingly.
Now calculate the DC blocking capacitors required in the source and in the power amp to suit your chosen frequency response. These are liable to be quite large and may need to be electrolytic//polyplastic.
Now calculate the maximum stray capacitances that the cables and PCB layouts will add. This effectively lowers the input impedance seen by the previous stage and raises the current capability required of the source to drive the subsequent stages.
The lowish impedances of the example will tolerate quite high values of pF. if you increase your source impedance then you risk losing some of the high frequency range due to unavoidable capacitances of passive pots.
regards Andrew T.
Old 22nd May 2008, 01:21 PM   #9
AndrewT, please remind me about the low pass filter created by the high impedance and cable capacitance.
I assume it is a one-pole filter with a corner at 1/ (2*pi*R*C)
The C would be the total capacitance of the cable (mainly)
and the R would (mostly) be 1/4 Pot value (asuming worst case where the pot is positioned half-way.
Did I get it right?
Old 22nd May 2008, 01:52 PM   #10
yes,
series resistance/impedance before the Capacitance and total capacitance after the series impedance.
But there is a second low pass filter before the pot as well, but it's frequency is likely to be considerably higher if short cables are used.
If long cables between source and pot and short cables/low stray capacitance after the pot then the two turnover frequencies could be similar, resulting in a Bessel (Q=0.5) turn over characteristic which has a slow attenuation rate below turn over frequency. You need to ensure this stays much higher than your pass band requirement.
I wonder if a target f-3dB >= 500kHz is worth aiming for both low pass filters?
Any comment?
regards Andrew T.
F1 and a passive preamp? roscoeiii Pass Labs 10 10th May 2009 12:55 AM
passive preamp mjh77 Analogue Source 4 14th August 2004 10:06 PM
Passive Preamp Rarkov Analogue Source 77 15th April 2003 06:51 PM
Passive preamp Flemming J P Everything Else 7 5th November 2001 09:40 AM
Page generated in 0.39937 seconds (27.29% PHP - 72.71% MySQL) with 11 queries
