Old 28th December 2007, 02:51 PM   #1
Default 48db/oct Subsonic filter
Has anybody built a filter like this?
Is for subsonic filtering, maybe 15-17Hz 48db/oct highpass.
It be worth?
La vida es bella.
Old 28th December 2007, 03:08 PM   #2
each filter has a Q of 0.7
When you cascade four of these, the Q of the whole circuit is 0.7^4=0.25
This is far too low.
You should alter the Q of each section to deliver a final Q between 0.5 and 0.7
regards Andrew T.
Old 28th December 2007, 03:25 PM   #3
Hi AndrewT:
Thank you for your answear
Maybe modify this, is too much to my knowledge.
Certainly its easyer build something proven, like this?
http://sound.westhost.com/project99.htm
La vida es bella.
Old 28th December 2007, 03:37 PM   #4
ESP has altered the Q of each section to give a fairly fast turn over.
That's why he warns you not to experiment with changes.
This type of circuit is much easier to design and build if you adopt equal value Sallen & Key filters instead of unity gain filters.
The disadvantage of evsk is that each stage's gain is greater than 1 and the total gain is usually too high. This can easily be solved by using MFB filters for the two highest gain (highest Q) sections. MFB are inverting stages and using two cancels out the inversion.
regards Andrew T.
Old 28th December 2007, 04:57 PM   #5
Hi Andrew:
I found the "Texas Instrumentes Filter Pro" design software, maybe this help me to understand more the complexity of filter design.
Thanks a lot
Iván
La vida es bella.
subsonic filter from 25hz - 0hz djronbxs Solid State 0 27th November 2007 06:43 AM
Subsonic filter bybass? jakelm3075 Subwoofers 14 16th March 2006 01:55 PM
Is it possible: passive subsonic filter? Geez Subwoofers 7 9th August 2005 05:50 AM
DIY subsonic filter anyone? BobM Analogue Source 4 25th August 2003 05:21 PM
Subsonic filter for a SubWoofer guylemar Subwoofers 10 28th March 2003 01:38 AM
Page generated in 0.07880 seconds (68.77% PHP - 31.23% MySQL) with 11 queries
