Kulish Corrector for Class-A EF O/P Stage - Page 10 - diyAudio
Old 7th April 2008, 05:52 PM   #91
Send a message via Yahoo to linuxguru
Default Input/VAS stage modifications
Here are some further modifications to the topology of the LTP and VAS stages, with the everything else removed for the purpose of LTSpice simulation. The main change is the use of Lender's dual drive to both the LTP active loads. All transistors are garden-variety commodity types.
It simulates with H2 ~= -126 dB, H3 < -145 dB, ... at VAS voltage swings of +/- 40 volts. Most importantly, even harmonics dominate the succeeding odd harmonics by ~20 dB each, potentially yielding tube-type sonics, but with vanishingly low THD.
Old 7th April 2008, 05:54 PM   #92
Here's the FFT plot for 20 kHz, 40V amplitude VAS output:
Old 16th June 2013, 11:52 PM   #93
Bigun is offline Bigun  Canada
Bigun's Avatar
It seems I never heard of this Kulish stuff until today - has everybody given up on this - looks very interesting...?
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 17th June 2013, 10:32 AM   #94
I had completely forgotten about it.
Seems Xpro became too busy to do the translation.
I note that in those days I still hadn't learnt to spell Lin correctly.
I used Linn, as in the Scottish manufacturer of the Sondek.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 18th June 2013, 06:50 PM   #95
Hi Linuxguru
did you asked the moderators to allow pornography
http://www.diyaudio.com/forums/attac...opamp1_fft.jpg without the balls?
regards, Pawel
Old 18th June 2013, 08:11 PM   #96
Bigun's Avatar
The distortion is very low, however, the open loop gain of his proposed amp was huge so I don't see much need for a Kulish cell - but with low feedback factors it should be very nice yet so little interest ?
Old 19th June 2013, 06:08 AM   #97
the simplest cell has geniuine fft for a few wats
it works now in deep A class with 1,3A idle
all it needs is a compensation which might spoil the sound...
regards, Pawel
Old 19th June 2013, 03:58 PM   #98
Is that -105dB for 2nd & 3rd, for an output stage without global NFB?
What is that @ ~ 23MHz?
regards Andrew T.
Old 19th June 2013, 07:18 PM   #99
unfortunately it is global cfb.
~ 23MHz is the oscillation
tomorrow I will send asc file to play with
regards, Pawel
Kulish Corrector applications GEirin Solid State 12 30th December 2007 06:52 PM
Copyright 1999-2017 diyAudio
