Amp design w/ Quad 303 features
Old 26th December 2007, 02:08 AM   #1
hahfran is offline hahfran  Germany
Default Amp design w/ Quad 303 features
The Quad 303 design ( 1970 or so ) had these unique features:
regulated single rail power supply
quais complementary triple cascade topology
inverting
The present design has dual unregulated supply but regulated supply for driver stage
the triple cascade is complimentary
the amp is inverting
the attached schematic has the defaults of the schematic editor
Old 26th December 2007, 02:15 AM   #2
lumanauw is offline lumanauw  Indonesia
diyAudio Moderator Emeritus
lumanauw's Avatar
Send a message via Yahoo to lumanauw
There should be R between LEDs?
Old 26th December 2007, 08:36 AM   #3
Yes a resistor between the blue LEDs is recommended
the value is 20 k
with the preliminary PCB layout the value of R30 cannot be larger than 2 k thus a buffer opamp is required in input. With higher values for R30 the transient response shows overshoot and ringing.
Transistors T6,T7 determine the quiescent current and its stability
I put these in a kind of micro oven that is the junction temp. is kept at 70C .
The quiescent current is set to 50 mA for test purposes. After sine wave packets 8 on 8 off at 1/2 max power in 4 ohms it does not
run higher than 52 mA.
That looks promising.
A more general problem is as follows:
the Quad 303 was designed thus that fT of the active devices increases from output to input.
This is a design directive according to tube amps, if the output transformer is taken into account.
In the present test device the output transistors are the good old
2SA1216 2SC2922 and the drivers are 2SA968 2SC2238
just because I've got a bag full of these for almost nothing.
These will require a sophisticated SOA protection.
More rugged transistors with higher Pd and lower fT could get along with only short circuit protection.
Dieter F.
Old 26th December 2007, 01:08 PM   #4
darkfenriz is offline darkfenriz  Poland
darkfenriz's Avatar
R18/R19 should be connected to unregulated supply
T9 should be npn.
Amp design w/ Quad 303 featuresHide this!Advertise here!
Quad ESL Design ak_47_boy Planars & Exotics 28 14th January 2007 06:42 PM
Quad 606/707 pcb design vzs Solid State 1 4th June 2006 06:56 PM
Quad bandpass subwoofer design need advice! DJFUTILE Multi-Way 6 29th March 2005 07:32 AM
Copyright ©1999-2017 diyAudio
