i bet i can turn any old naim amp into a giant slayer
i have just modified a budget musical fidleity amp to kick a modern roksan into touch naim charge a lot of money just for a re capp i could save you megga bucks and tell you what parts to get |
#2 |
Im all ears!
What Naim amp and parts do you suggest? |
#3 |
hi any naim from nap 140 to 250 to naim nap 160 naim nait .and naim nait 2 & nait 3 to be honest any naim amp with bigger better spec replacement transformer, and bigger hi quality power supply caps
will sound miles better than standard maybe beating their newer more exspensive amps this musical fidelity amp has jumped from a pile of rubbish to a very end amp your amp if it is better than this will sound much much better if you want to know what parts to use,i need to know what amp you have otherwise the transformer may not fit in the case and it would be handy to know what the ac voltage is from your current transformer easy to do if you have a muliti meter |
#4 |
Hi, Ive got a chrome bumper nap 250, recapped with kendeil main smoothers, star earthed, feedback loop cap is now polyester, resistors in the signal path are vishay dale rn60, no coupling cap (got one on output of preamp) and an rc filter on the input of the regulator board.
What else do you suggest i do? Cheers matt |
#5 |
hi matt change the transformer for a very hi va at least 500 to over 800va i am not sure what your nap 250 naim transformer va is, but go much bigger and if your caps are the 10.000 make them 22.000 mf and make sure you choose one that is very low noise avondale sell them ,or you could find a good one at RS or farnel
also add inlet mains filter replace your iec soket in your amp as this makes a big improvement if your mains is dirty which i am sure it will be |
#6 |
Why not simply try an SMPS ... like the ColdAmp SPS80 ...
http://www.coldamp.com/opencms/openc...S80/index.html ciao
KL. |
#7 |
Interesting stuff.
You should start a thread on www.pinkfishmedia.net . Loads of people modify Naim kit on that forum. |
#8 |
"hi matt change the transformer for a very hi va at least 500 to over 800va i am not sure what your nap 250 naim transformer va is, but go much bigger and if your caps are the 10.000 make them 22.000 mf and make sure you choose one that is very low noise avondale sell them ,or you could find a good one at RS or farnel
also add inlet mains filter replace your iec soket in your amp as this makes a big improvement if your mains is dirty which i am sure it will be" Sorry, dont know how to quote messages properly. The bigger caps i understand, but then if they are of a suitable size to start with (which in most gear they probably are not) then this surely couldnt make any difference. The transformer upgrade, is to charge the bigger caps more quickly? Again if it needs upgrading the original was too small, all for the sake of maybe 15% higher price.... What I'm trying to say is that I dont understand why people pay a lot of cash for equipment that isnt properly made! I learnt most of my electronics stuff from some old guy in my town, and some of the numbers he has shown me are shocking. I have never seen a power supply in comercial equipment that was of a suitable size. Well, hope you had a good chrismas, sorry for the rant! |
#9 |
Naim nait 2 here. What caps do I need?
#10 |
For a nait 2 you should look here www.acoustica.org.uk
| What to do with a 5k output transfomer? | Switch | Tubes / Valves | 17 | 23rd July 2008 08:12 PM |
| Recapped the Imperial 7s tonight | geaugafletcher | Multi-Way | 2 | 26th April 2006 04:26 PM |
| Input transfomer on P3A | jesper | Solid State | 9 | 30th October 2004 07:39 PM |
| Think this is worth $60? (transfomer) | Hybrid fourdoor | Swap Meet | 5 | 22nd June 2004 10:56 AM |
| Characters getting bigger and bigger | Elso Kwak | Everything Else | 11 | 31st May 2003 10:43 PM |
| Page generated in 0.12985 seconds (84.00% PHP - 16.00% MySQL) with 11 queries |
