Old 20th February 2003, 08:44 PM   #1
Question SIT Power Amplifier???
Hi everyone!!!
there is the japanesse page with many designs, among them there is sth called SIT amplifier - where can I find some info about that???...in english of course
I tried translating with altavista, but effects are not good...
the site:
http://www.ne.jp/asahi/evo/amp/SITamp.htm
thanks.
Old 21st February 2003, 11:38 AM   #2
JohnG is offline JohnG  United States
Try searching Google for "static induction transistor". It's been a while, but this is something akin to a power JFET, or maybe a power MESFET (not MOSFET!).
John
Old 21st February 2003, 11:49 AM   #3
dimitri is offline dimitri  United States
dimitri's Avatar
Send a message via ICQ to dimitri
Default I'm affraid TKS45F323 is out of production
http://www.rsc.rockwell.com/html/electronics.html
For much higher levels of output power, we have two distinct technologies that cover complementary frequency ranges, both based on wide bandgap semiconductors. These have inherent advantages over conventional semiconductors in terms of higher temperature of operation and higher breakdown voltage. A SiC based MESFET (metal semiconductor field effect transistor) and SIT (static induction transistor) have been developed for use in X-band and L-band, respectively. These offer several exciting application options including a myriad of military communication bands at L-band and below, as well as future cellular phone base station amplifiers. For higher frequencies, we are developing a GaN based HEMT technology that has demonstrated high power performance at X-band and above.
The new tokin sites:
http://www.iijnet.or.jp/EMCE/index-e.htm
http://www.nec-tokin.com/
Translation from:
http://www.ne.jp/asahi/evo/amp/SIT/page1.htm
http://www.ne.jp/asahi/evo/amp/SIT/page2.htm
The SIT because it is the element of 3 polar vacuum tube type qualities whose resistance inside the drain is low, when it uses for the output step of the power amplifier, not depending on the NFB, you can obtain low output impedance. The on that, it meaning that input resistance does not require power for drive high, it can construct the power amplifier in quite the simple circuit.
The SIT was proposed in 1950 by Professor and others Tohoku University Nishizawa. The usual connecting type field-effect transistor (the JFET), controlling the electric current which flows to the channel, due to the depletion layer you obtain transistor quality, but because the channel is long, channel resistance (source resistance) becomes high, on resistance large, operational speed slow. In addition electric current is saturated by the negative feedback effect to which drain voltage operates the depletion layer. Then, when the channel is made short, channel resistance is made to decrease to the extremity, the negative feedback effect does not occur, electric current is not saturated can obtain " 3 polar vacuum tube type qualities ". This effect with the electrostatic induction effect, the electrostatic induction type transistor (the Static Induction Transistor SIT) with is the transistor which utilizes this. The SIT and so on is warped loss and high-speed operation, low and low has feature.
Old 21st February 2003, 06:15 PM   #4
Default Yamaha B1 Amplifier
SIT Fets were used in the output stage of the Yamaha B1 amplifier, back in the mid 70's. Depletion mode devices like these are harder to interface with and drive, as solid state devices go, but then there weren't any conventinal vertical DMOS transistors at this time (Siliconix VMOS and IR and Siemens DMOS were a few years away from commercial release), so this was pretty innovative for it's time. Making the transistors, particularly the buried gates, is pretty tough, especially with consistency.
-Jon
Old 24th February 2003, 12:14 PM   #5
jcarr is offline jcarr  United States
New link of SIT amp:
http://www.ne.jp/asahi/evo/amp/CSPP/2SJ18.htm
Sony's SJ18 devices have been out of production for many, many years, so you would have to be very lucky to make use of the information on this page.
Interesting nonetheless...
regards, jonathan carr
http://www.lyraconnoisseur.com/, http://www.lyraaudio.com
Old 24th February 2003, 12:25 PM   #6
Thank for feedback!
It seems that not many projects there are on the net using SIT transistors...
There is another page:
http://www.mobara.ne.jp/~yamada/sit/index.html
in japaneese of course
Old 29th August 2004, 02:19 PM   #7
nl is offline nl  United States
Default available etc
I listened to SIT-based amps while in Tokyo a couple years ago. Quite promising. The Tokin SIT is apparently available from Hino Audio. Look at this link for more info.
It is quite expensive, quoted at 60,000 yen for a set of four. Note that, due to its ability to swing large voltages (450V), and limited current output (4A peak, about 400mA idle common), it is normally used with an output transformer! Indeed, Plitron makes a toroidal solid-state OPT that would fit this unit nicely.
Old 22nd May 2006, 07:03 PM   #8
hi,
how about the sound quality of this sit amp????
thx
thomas
Old 26th January 2009, 08:31 PM   #9
frankln is offline frankln  Italy
frankln's Avatar
do you know how to adjust VR1, VR2 & VR3?
Rockford Fosgate Power 20001 bd amplifier power rating?? pachoorion Car Audio 8 8th May 2011 10:49 PM
Power transformers versus amplifier output power..what is your option? destroyer X Solid State 38 9th May 2009 05:23 PM
McIntosh Power Amplifier Power Guard johnnyrt Solid State 2 23rd August 2007 10:22 PM
Output power for a power amplifier Progg70 Solid State 33 10th September 2006 08:44 AM
Amplifier 3000 Wats Rms Power + Smps Higcht Power Bestiality MARAVILLASAUDIO Class D 1 5th November 2004 04:06 PM
Copyright ©1999-2013 diyAudio
