uPC1237/NTE7100
uPC1237/NTE7100
Old 27th December 2012, 05:33 PM   #41
ceteras is offline ceteras  Romania
I've found a local shop that has 3 pieces. I wonder where they've got them from.
Old 27th December 2012, 06:25 PM   #42
jaycee is offline jaycee  United Kingdom
Probably just old stock. The only place I can now find upc1237 is on eBay, and that is a gamble.
There's a potential for a nice little project here I think - a upc1237 replacement board
Old 27th December 2012, 06:46 PM   #43
availlyrics is offline availlyrics  India
availlyrics's Avatar
I bought UPC1237HA from a local store in Mumbai for like 1$/pcs, if anybody wants it - can PM me. About quality/genuine, I've been using it for about 2 months or so & they seem to work perfectly.
Old 27th December 2012, 06:52 PM   #44
That is exactly what I will do if the parts at the shop will fail.
I would use the circuits from Rod Elliot's project here as inspiration.
Old 3rd January 2013, 04:09 PM   #45
No luck with the C1237HA, it was money sent down the drain.
In my application, the Vcc is 20V, and all four pins no. 4,6,7,8 are at the same voltage: 20V.
It's just like I didn't solder the chip on the board, and I've triple checked everything.
I will try an original uPC1237 from an Akai amplifier just to verify if the circuit is allright. If it works, I'm going to start designing the replacement board for this chip.
Old 3rd January 2013, 06:12 PM   #46
Update: uPC1237 from the Akai amplifier works like a charm.
So I know not to buy anything else from that shop, perhaps except resistors.
I'll finish my project with this chip, and think about the replacement board after that.
Old 3rd January 2013, 06:21 PM   #47
Bill_P is offline Bill_P  United States
NAD has designed a small board to replace the uPC1237. See this thread for details: NAD C315BEE - Help with repair!
Old 8th January 2013, 02:52 PM   #48
I've NAD C352 amp(Manufactured -Oct 2004) & it uses UPC1237 . It uses standard value passives as mentioned in UPC datasheet.
Old 8th January 2013, 02:56 PM   #49
Yeah we poor DIYers are sitting ducks for these counterfeiters. Keep us posted about your results with the original uPC1237 from Akai.
Old 8th January 2013, 03:10 PM   #50
Excuse my poor English , but I've written about it a couple of posts above. It works fine with the good old NEC uPC1237 from the Akai.
I've tried to crack open the counterfeited chip, hoping to prove that there is no silicon inside (that's what I expect).
Unfortunately I've broken it in too many pieces.
uPC1237/NTE7100Hide this!Advertise here!
Question on uPC1237 Buzzy Solid State 18 3rd August 2008 01:22 AM
Upc1237 Ic d3imlay Solid State 3 7th February 2008 12:14 PM
upc1237 circuit diagram.. clovi_kate Solid State 1 4th May 2007 10:16 AM
UPC1237 IC Amp Protector matt09 Chip Amps 5 2nd November 2006 06:59 PM
Problems with UPC1237 Risto80 Solid State 4 27th December 2004 02:38 AM
