Old 17th February 2008, 08:23 PM   #11
zeonrider's Avatar
Default 2
2
Old 17th February 2008, 08:24 PM   #12
zeonrider's Avatar
Default 3
3
Regards zeoN_Rider
Old 17th February 2008, 09:36 PM   #13
Nordic is offline Nordic  South Africa
Nordic's Avatar
Hallo loek, I replied to your e-mail...
Nice layout Zeon... interesting the dual relay...
May I ask why you chose that over the single relay...? also does it still fall within the chip's output rateing to actualy handle two relays?
Old 17th February 2008, 09:47 PM   #14
zeonrider's Avatar
Default Hi Nordic!
1.I, like simetry, & simple I, have it,
2.yes!
Regards zeoN_Rider
Old 18th February 2008, 02:03 AM   #15
jaycee is offline jaycee  United Kingdom
Personally i've never seen the point of using such IC's in a DIY design. Commercial offerings use them in order to save parts count and cost, but it's much better to do something discrete especially as these IC's often go obsolete.
These days it's often done discrete anyway, but usually strictly as a detector - this is then fed to the amp's microcontroller which controls the speaker protect relay and/or the power relay.
Old 18th February 2008, 11:58 AM   #16
loek is offline loek  Netherlands
Default uPC1237HA
I found them overhere Nico.
Thanks Jan and Nico for the help finding those chips.
Regards, Loek
Old 18th February 2008, 09:49 PM   #17
d3imlay is offline d3imlay  United States
Default Re: 3
Originally posted by zeonrider
3
Zeon,
Nice work. I'm working on a similar project and have found that the voltage at pin 2 will not exceed a few volts which would allow for a lower voltage cap. Also, why use 2 in series when bipoars are available? I always subscribe to the notion that unused input pins on a chip are tied to ground or V+ to avoid noise issues. On mine I have a zero ohm resistor going to ground on pin1. I also brought out pin 1 to a terminal, through another zero ohm resistor so that it could be used at a later date in case I want to add an over current sense.
Regards zeoN_Rider
Jaycee
I agree with you that discreet would be desirable. In my application I have limited space for a board. I'm banking on this chip being available for a while since NTE has an equivalent.
Old 19th February 2008, 05:50 AM   #18
Nordic's Avatar
buy 5 and stick them to the inside of the case, like spare fuses if you are paranoid...
Old 19th February 2008, 06:32 AM   #19
jan.didden's Avatar
[snip]Commercial offerings use them in order to save parts count and cost, but it's much better to do something discrete especially as these IC's often go obsolete.[snip]
Obsolescense is often a problem, although these chips, because a lot of manufacturers use them - will probably stick around some time.
In what way would a discrete circuit be better?
Jan Didden
/Yes! Its out: Linear Audio Vol 5!
I'm not an "accademic", just a plodder who loves a challenge - Ian Hegglun
Old 14th March 2008, 08:27 AM   #20
Small-signal transistors suitable for the job will always be available
Question on uPC1237 Buzzy Solid State 18 3rd August 2008 01:22 AM
Upc1237 Ic d3imlay Solid State 3 7th February 2008 12:14 PM
upc1237 circuit diagram.. clovi_kate Solid State 1 4th May 2007 10:16 AM
UPC1237 IC Amp Protector matt09 Chip Amps 5 2nd November 2006 06:59 PM
Problems with UPC1237 Risto80 Solid State 4 27th December 2004 02:38 AM
Copyright ©1999-2013 diyAudio
