Old 20th December 2007, 02:36 PM   #1
rtill is offline rtill  United States
Default 60 watt design...
Does this look like a good design for a power amp?
http://www.redcircuits.com/Page65.htm
Old 20th December 2007, 03:10 PM   #2
jaycee is offline jaycee  United Kingdom
No.. it'd work, thats about all you can say about it.
There's some good circuits on Sam's page: http://users.otenet.gr/~athsam/index.htm
Or theres Rod Elliot's P3A: http://sound.westhost.com/project3a.htm
Or MikeB's SymAsym: http://www.lf-pro.net/mbittner/Sym5_.../symasym5.html
Or Destroyer X's amp: http://users.tpg.com.au/users/gerskine/dxamp/
The last two have PCB designs available which means you won't have to design one. Rod sells a PCB for his P3A amp.
Old 20th December 2007, 03:47 PM   #3
sreten is online now sreten  United Kingdom
It is suitable for purpose, i.e. a guitar amplifier, but a very poor hi-fi amplifier.
/sreten.
Old 20th December 2007, 07:58 PM   #4
is it possible to change the voltage and output transistors to get 150 watts?
Old 20th December 2007, 10:26 PM   #5
MJL21193's Avatar
150+ watts here . Compare.
Old 21st December 2007, 12:16 PM   #6
sakis is offline sakis  Greece
sakis's Avatar
Default dont you .....
even think about it ....
SERVICE ΙΑΠΩΝΙΚΩΝ ΜΗΧΑΝΗΜΑΤΩΝ ΗΧΟΥ www.eastelectronics.gr
Old 21st December 2007, 09:58 PM   #7
No. You cannot simply beef up the transistors and increase the voltage - the whole circuit needs to be designed for that. If you want a 150W amp, then go for a circuit designed for it.
Old 10th January 2008, 03:07 PM   #8
Default fire fire fire
so I built this amp 3 times with all new parts each time.....and R4 keeps starting on fire.....what's going on????
Old 10th January 2008, 03:16 PM   #9
sakis's Avatar
Default i am so sorry
canot really help you since the data you provide is not enough .....
but if you like to have some other smoke producing devices i have a few to point for you .....
ONLY JOCKING !!!! BEST REGARDS SAKIS
Old 10th January 2008, 03:20 PM   #10
Donk is offline Donk  Europe
Donk's Avatar
R4 keeps starting on fire? Then there is something really really bad there!
Is Q2 still alive?
Plase provide us some meaurements as Sakis asked.
What is your rail current consumption? What's your output DC offset?
Any oscillation?
What PCB design did u use?
Etc..
1000 Watt Sub Amp: Design / Build MJL21193 Solid State 327 1st July 2009 12:14 AM
First Watt F3 / Tube Audio Design TAD-125 Hibachi JFET amps vizion Tubes / Valves 1 31st August 2008 03:08 AM
Wilson Watt Puppy Clone Design - Design Review Please soundengine355 Multi-Way 8 15th August 2008 02:07 PM
Help me design a pcb for redcircuits 10 watt amp.. rajagopal87 Solid State 4 1st March 2007 10:58 PM
My 50 Watt RMS design using Randy Slone's formulas corrieb Solid State 18 14th January 2007 12:22 AM
Page generated in 0.09853 seconds (78.87% PHP - 21.13% MySQL) with 10 queries
