anyone have a chance to compare this -- seems that they were introduced in September but I didn't see a press release:
http://www.onsemi.com/pub/Collateral/NJW3281-D.PDF |
#2 |
I just received an e-mail from the product line manager at On Semi. Here's what he had to say about these parts:
"Our roadmap for the coming year is centered on the TO-3P package we are getting ready to introduce. This portfolio of devices uses the same die as our TO-264 parts. The lower cost TO-3P package will hopefully allow us to capture more of the cost competitive mid-range consumer business without sacrificing performance" |
#3 | |
#4 | |
I like TO-3, just becuz I rebuild amplifiers and the holes are already there. |
#5 |
Still comes up a bit short on SOA when compared to a typical mosfet device such as 'this' with the same case style. Over 30V with 10A DC from a plastic TO3P
All the trouble I've ever been in started out as fun...... |
#6 |
I'm a bit confused. What's the difference between the MJW (1302/3281) and NJW series? Just TO-247 vs. TO-3P? I don't see much difference between the two in terms of physical footprint. Is there an electrical difference?
Obviously the NJW is smaller than the MJL series TO-264 package, but doesn't the MJW series already provide the size advantage they're after? Or is there more to it than I'm seeing? ..Todd |
#7 |
OnSemi case codes:
NJW: TO3P MJ: TO3 MJD: DPAK4 MJE: TO220/225 MJF: TO220-ISO MJL: TO264 MJW: TO247 NJL: TO264-5 (with integrated t-comp diodes) An effective difference in parameters other than Vcbo/Vceo seems to be in the 0302 vs 1302 (0281 vs 3281, resp) varietes, the "0"-version are smaller die (less Pd) and have less capacitance. For same number devices vs. case style (NJW, MJL, MJW) I see no significant differences (besides Vcbo/Vceo) - Klaus |
#8 |
Did anyone else notice that the Rth(j-c), power dissipation, thermal derating and maximum power dissipation don't add upp for many of the ONSemi plastic parts? (MJL21193, MJL3281...)
Rth(j-c) is stated as 0.7K/W and thermal derating as 1.43W/K. This would suggest a power rating of 180W. Or a typo as this is the same values as stated for the 250W metal cans. Strange is that the mjw3281a datasheet says 0.625K/W (this works out to 200W) but the MJL3281 in the bigger TO264 says 0.7K/W. I have a hard time believing that the smaller package has better thermal properties... I wonder too what is the advantage of TO3-P vs. TO247. Maybe it is cheaper in some way. Or maybe it's just the japanese transistor looks they are after :P |
#9 |
250vce vs 230vce and also better hfe across most of the load spectra.... At a $1.48 a pop at Digkey... I ain't complaining. Sustained beta's for me!
#10 |
I thought To3p was a generic title for all large plastic packages.
Now, it seems that ONsemi are saying that To3p is different from To247 and different from To264. What exactly is To3p?
regards Andrew T. |
| wanted: Coral Beta 8 or Beta 10 full range speaker | francofil | Swap Meet | 2 | 28th April 2010 08:34 AM |
| Class-D lack of sustained bass Myth | Zero Cool | Class D | 15 | 9th July 2009 05:41 AM |
| Krell's sustained plateau sliding bias | h_a | Solid State | 2 | 9th December 2008 04:31 PM |
| OnSemi ThermalTrak | Arius | Solid State | 8 | 26th August 2005 04:09 PM |
| Page generated in 0.11316 seconds (81.08% PHP - 18.92% MySQL) with 11 queries |
