I just bought a very cheap amplifier fromr thomann.de, a t.amp S75. Although it seems to be good value for the money at first (torroid transformer, good connectors, etc.), it sounds terrible at low volumes. The level of distortion is unaccpeptable, even having low demands. The reason for that was quickly identified: An idle current at the output transistors was simple not existing, thus leding to excessive switching distorions. It is not possible to raise the voltage between the driving transitors to a level that would cause an idle current (approx. 4x0.7V) in the original configuration, even with the trimmer full clockwise. So I shunted a 10k resisor in parallel with the existing 2k resistor near the idle current trimmer (both, the 200 Ohm trimmer and the 2k resistor are between base and emiter of the small "virtual zener-diode" that defines the bias voltage between the dirves bases) which increased the bias voltage range about 20 percent. This allows to set the bias current to a reasonable value. I chose 10mA. The switching distortions disappeart. Hope, this helps other S75 owners... Cheers, Hering |
#2 |
It does!
Thanks for the idea! |
#3 |
Servus hering,
Can you tell us more of the internal? What power transistors are in there, etc.... Pictures would be great too! Thanks, Markus
regards / servus |
#4 |
Hello,
Here .... 2SA1013 2sa1015 2sa1837 2SA1942 2sa970 2sc2240 2sc4793 2SC5199 IMHO it sounds horrible but I don't think I could build it for 98euros!! It WILL be modified of course |
#5 |
hmm, this ones height is 1HE...
I think for an amp to mod, a E400 or E600 would be the better start.
regards / servus |
#6 |
You are right of course but I wanted 1U due to limited space.
Anyway, the mods will be in electronics arount input mostly so no bulky parts like psu filter caps and xformer will get involved. |
#7 |
Did you try some mods in the mean time? Does the increased bias current improve the sound?
I have the same unit, a lot of parts for the money, good build quality. I don't hear distortions but the sound is a bit boring and it hums slightly. Could be interesting for active speakers if modding can solve above issues. Does somebody have the schematics? Joe |
#8 |
Yes joe, bias increase does improve sound. Heat also goes up a bit.
No schematics sorry. |
| Changing grid leak bias preamp to cathode bias | bereanbill | Tubes / Valves | 8 | 28th March 2009 05:26 PM |
| Stray hum pickup *preamp* cathode R-bias vs. battery bias & 12AU7vs.5687 | awedio | Tubes / Valves | 2 | 19th April 2008 01:30 AM |
| Battery grid bias to fixed bias in Toccato? | w00t | Tubes / Valves | 3 | 2nd December 2007 12:34 AM |
| Supressed bias amplifier, automatic variable bias system. | destroyer X | Solid State | 2 | 20th September 2004 10:24 AM |
| End Millenium bias adjustment modification? | Cradle22 | Solid State | 0 | 26th August 2003 01:35 PM |
| Page generated in 0.09485 seconds (76.52% PHP - 23.48% MySQL) with 11 queries |
