hi,can anybody help me?
is possible and easy,convert an aexposure XXI from 125 volts to 220 volts? my i do it my self? thanks at all. |
#2 |
First all I must tell that the voltages in the transformer and around it are lethal and must be done attention in all operations.
Yes, if It's possible to find a tranformer (toroidal I suppose) with: - same power (or higher) - same number of secondaries and same voltages output rated at 230 Vac input (to primary) - compatible dimensions to the original. The problem is having these informations. I council you to contact Exsposure for the 230Vac replacement transformer, I suppose that It's possible to do it. The direct inspection by tester is problematic because the italian Vac voltage is 230 not 110-120 Vac and connecting the amp to 230 Vac it's very dangerous (be carefull). A solution can be is finding the schematics or connecting the amp to an AC adaptator from 230Vac to 110 Vac (be carefull to max power rated) and testing the secondaries , before all it's necessary to disconnect the secondaries from rectifier(s). It's possible to use an sin generator (function generator) for tested but this a secondary way.
PP |
#3 |
is not allowed to move 4 wires inside:from serial to parallel?
many tranformer are both for 125/220 just rewired in this way. |
#4 |
Many but not all, several transformers are made for one AC voltage supply only and they have one primary only.
I think if amp's transformer had two primaries then exsposure would have placed an AC selector inside amp. However, I think this transformer probabily is a standard type and It's possible (but this it's not probabily) that on it there is a label with secondaries voltages and rated power. For the forum's rules I must tell you that you can operate inside amp only if you are competent in electronics. Prudence always.
PP |
#5 |
can you send me some photos inside the preamp, please?
PP |
#6 |
i'm watching an ebay item,and the seller don't send me the photos,so...
many thanks anyway for your interest. |
#7 |
Exposure is made in the EC and either has a 230Vac or a dual 115/230Vac transformer fitted as standard. It is very easy (if it's not a Krell) to change voltage to suit any country.
regards Andrew T. |
#8 |
so if i get the item can help me?
#9 |
Now I have find some preamp's photos and this preamp is an120/240 ac model , AndrewT you are right ,
PP |
#10 |
If you want I can help I think , now I go just to listen my new preamp that I have designed (we are speaking about preamps....).
See you later guys.
PP |
| Help needed with PCB UV Exposure box | zeus_threat | Everything Else | 12 | 7th October 2008 04:50 PM |
| DIY UV Exposure box with UV LEDs | Nordic | Parts | 54 | 1st October 2007 09:58 PM |
| EXPOSURE X Integrated Amp Help | arupg | Solid State | 3 | 21st February 2007 09:41 PM |
| Exposure 7 pre amp help | hifienthusiast | Solid State | 7 | 28th March 2006 08:25 AM |
| Page generated in 0.09956 seconds (77.82% PHP - 22.18% MySQL) with 11 queries |
