this amp work? this amp work? - diyAudio
this amp work?
this amp work?
Old 12th December 2007, 10:17 PM   #1
tadiam is offline tadiam  Argentina
Send a message via AIM to tadiam Send a message via MSN to tadiam Send a message via Yahoo to tadiam
Default this amp work?
:xeye:
audio
Old 12th December 2007, 10:36 PM   #2
wg_ski is offline wg_ski  United States
This one is at least... unique. I'd keep a fire extinguisher handy - my first impression is that the output stage is gonna run away and you'll need to go catch it. Does it *simulate* ok?
I guess the idea was totally golbal-NFB-free, and not just a tweak on an existing topology? But four stages of current gain - with no Rbe's and no bias tracking is likely to get stupid on you. Might also drift around quite a bit unless Q3-6 were very well matched and epoxied together.
What have you got to lose - 60 volts won't bring down the building and there's nothing expensive in there.
Old 12th December 2007, 11:06 PM   #3
Duo is offline Duo  Canada
Duo's Avatar
Send a message via ICQ to Duo
Hm... This thing is very weird..
Old 12th December 2007, 11:15 PM   #4
CBS240 is offline CBS240  United States
CBS240's Avatar
Hi
I think the DC bias would be OK, but there would need to be a Vbe multiplier or some temperature compensation if this is class AB. However, as for the current mirrors used as the VAS, linear gain might be questionable. The problem is when the circuit is powered up, C1 and C2 will require current to charge up. This current will come from the mirror source transistors and be reflected in the mirror devices. This will cause the outputs to burn up because their bias is dependent on the VAS current. I would not even try this circuit unless you have a secret vendetta against some poor output transistors.
All the trouble I've ever been in started out as fun......
Old 13th December 2007, 04:04 PM   #5
Default thanks
thanks
audio
Old 13th December 2007, 05:12 PM   #6
stoN_Cold is offline stoN_Cold  Serbia
stoN_Cold's Avatar
Default Hi tadiam !
Connect PSU & Trie .
Regards zeoN_Rider
Old 13th December 2007, 07:50 PM   #7
Default re
hi
audio
this amp work?Hide this!Advertise here!
Would this work ? LesPaulStandard Instruments and Amps 3 4th May 2006 02:14 AM
Will This Work? sousmielie Class D 6 27th December 2005 05:53 PM
It Should Not Work ! f4bok Solid State 3 6th September 2004 05:33 PM
Would this work? JoeBob Solid State 5 18th July 2003 03:40 PM
Copyright ©1999-2017 diyAudio
