a heretical preamp
a heretical preamp
Old 19th February 2003, 11:02 AM   #1
costiss is offline costiss
costiss's Avatar
Default a heretical preamp
ok.. its sure im certainly in for some flaming with this.. but i cant do elsewise.. i have built an opamp preamplifier (that is, with ic's...) here it is: what can i do to get it better? (only gainstage shown.. supply ordinary LM stuff) resistors cheap metal films hand matched to 0.1% (holco's on the way), decoupling through Elna RJH. pot alps 27mm.. so?
i am currently using 60,000 uF of capacitance in my preamplifier..
Old 19th February 2003, 11:17 AM   #2
peranders is offline peranders  Sweden
Electrons are yellow and more is better!
peranders's Avatar
a heretical preamp
I would recommend 10-100 nF polyester 63 V or ceramic, SMD as a complement to 120 µF. In fact it's more important with small high speed caps than big electrolytic. OPA627 is rather fast and therefore you need decoupling which is fast.
/Per-Anders (my first name) or P-A as my friends call me
Group buy: DCT03 DC trap for big toroidal transformers. Sign up for interest HERE. 41 pcb's in interest.
Old 19th February 2003, 06:10 PM   #3
ThorstenL is offline ThorstenL  Germany
Previously: Kuei Yang Wang
Default Re: a heretical preamp
I could think of a few things....
Howzdat for freaky?
Basic design is an amalgam of stuff I played around with before but with a battery supply, PSU where also tried at some point in time, in a Phonostage. Circuit drawn by Carlos M.
Recommend placement of the feedback resistors (all Op-Amp's) as SMD Resistors soldered directly at the pins. Powersupply is per supplied chip, wiring between regulator out and supplied chip must be minimal and no supply decoupling should be applied. If critical apply a 100pF SMD COG Cap between the positive and negative supply of the amplifier chip.
Pot should be ideally 1K log which is difficult at such low values. Alternatively a 220 Ohm Linear should work okay with a 470 Ohm "build out" resistor, please use cermet track pots if you can, if not carbon. Also, then you need to compensate the gain loss. Maximum output Z with 470R & 220R Pot is around 200R, with 300R & 1K Log it is 230R, both at maximum volume.
Sadly, transformer based attenuators as passive linestage are notably better still....
Sayonara
Old 19th February 2003, 06:33 PM   #4
Helix is offline Helix  United Kingdom
Helix's Avatar
Default Re: Re: a heretical preamp
Originally posted by Kuei Yang Wang
........... no supply decoupling should be applied.
why?
Old 19th February 2003, 07:04 PM   #5
Default Re: Re: Re: a heretical preamp
why?
I thought that would be obvious. The individual Op-Amp used as "regulator" does not tolerate much capacitive load. Up to around 100pF will be okay, much more and the thing will oscillate at VHF frequencies....
Sayonara
Old 19th February 2003, 07:43 PM   #6
peranders's Avatar
a heretical preamp
The schematics is slightly wrong. The LM431 is a little bit wrong connected. Cathode upwards and anode downwards.
Old 19th February 2003, 08:09 PM   #7
Helix's Avatar
Default Re: Re: Re: Re: a heretical preamp
Sayonara
sure, there would be a problem with capacitive load.. but i would put on as much as i could get away with say 68pf
also if u have time.. please discribe your thoughts on those input FETs
Old 19th February 2003, 08:35 PM   #8
halojoy is offline halojoy  Sweden
On Hiatus
You are doing fine, costiss!
Very good OPamp OPA627 (peranders has just bought some)
Metalfilm matched resistors
ELNA caps
ALPS potentiometer
And I am sure you will get a good Power Supply.
You already got the best boys as assistance!
Congratulations!
/halo - wish he had some Good Components at home
- maybe time to place an order????
Old 19th February 2003, 10:58 PM   #9
Christer is offline Christer  Sweden
Kuei,
Thanks for an interesting design. I have two questions about
the regulator part.
1) It seems reasonable that all the regulators share the
circuitry connected to the positive inputs (ie. the reference
voltage circuitry). Do you agree on this?
2) Would you consider it sufficient that they also share the
capacitors on the preregulated rails, or should these be
per regulator and as close as possible to them?
Just like a previous poster I am also a little bit curious about
the JFET buffer. I assume the purpose is to make the input
impedance invariant of the attenautor. However, I see that
they use a fixed Vgs of 0V and have no feedback. I assume
this particular topology is intended to be very linear, but I
do not quite see why or how (although it is a bit late and I
am tired, I admit). I also guess they have to be well matched.
Old 19th February 2003, 11:16 PM   #10
Yes. If you need for example for a Phonostage two gainstages per channel you can use dual Op-Amp's, assuming the layout remains tight.
Doing this on PCB's almost literally means using two PCB's arranged with the two soldersides touching, locating each regulator chip output pin directly next to the supply pin driven by it. In short, think 3D not 2D.
The latter. The smalles (physical & value) capacitor closest to the chip then the larger ones. The PSU Reg Chips do need to be stabilised against oscillation by having their supply pins well decoupled.
Well, the input impedance IS invariant of the Attenuator, but as the circuit is following the SPEEDO Axiom and the INVERTING Axiom the input impedance is rather low. The two Idss @ 15V matched (and thermally connected) J-Fets simply buffer the low input impedance of the Op-Amp and provide a high impedance input, in fact pretty much as high as you like (1M no sweat)
I assume this particular topology is intended to be very linear, but I do not quite see why or how (although it is a bit late and I
Actually, the topology is not intended to be very linear, it actually is. Driving 3V RMS into 1k will give around 0.008% THD, or better noted -82db THD, and this THD is rather low order and thus of low subjective sonic impact.
Yes, one could have used an OPA627 connected as follower, but somehow this simple J-Fet buffer struck me as more "Zen", just as the J-Fet MC stage on the Phonostage that this linestage was matched with (namely the "analogue addicts phono") seemd a better idea than a gain of 20 AD797. I guess it's a question of "designers fingerprints".
Ciao T
a heretical preampHide this!Advertise here!
A Heretical Unity gain line stage SY Tubes / Valves 87 4th October 2015 03:24 AM
heretical unity gain OUTPUT stage... andrew_whitham Tubes / Valves 4 9th December 2006 03:36 AM
Lundahl LL1540 for SY's heretical? Andypairo Tubes / Valves 9 6th October 2006 07:45 PM
heretical unity gain and ccs question selfwilly Tubes / Valves 14 28th March 2006 02:54 PM
Line stage preamp, based on SY's "Heretical Unity gain line stage" Danko Tubes / Valves 23 18th July 2005 04:07 AM
