Greetings everyone...
I'm keen on building a pair of (updated) JLH amps to drive the tweeters in my bi-amped system. I've devised a pcb for them, and i'm currently seeking validation and maybe some tips for improving the layout. The schematic can be found at this site . I'm attaching the current layout here. |
#2 |
Nice PCB
What kind of outputs are you considering for this design?
JLH 2005, Cyrus and so on... |
#3 |
Following some recommendations from that site, i was considering MJL21194's. It's said to oscillate if faster devices are used.
PS: another reason is that i can source some as samples from OnSemi |
#4 |
#5 |
I think i stumbled upon that page sometime, but the board is quite big. It says somewhere that the board is 160x100mm. Mine is about 1/4 that size (around 85x50mm), and in don't really have any huge cases available at the moment
#6 | |
Kind regards Nico |
#7 |
If you are going to use it for your tweeters only, why need to double up on the power transistors, one pair would be more than adequate for 10 watts or so.
Regards Nico |
#8 |
Experimented with this one using Mosfets some weeks ago. Sounds great and good for about 12 watts.
I have no idea why use CCS they make neither sonic nor measurable difference. |
#9 |
Then what about this, which includes your HF filter. The output cap is also nice for protecting your delicate tweeter against dc.
Ciao |
#10 |
I took your advice and moved the caps. I had a bit of work uniting the grounds, but i hope i haven't messed it up more than it was before
| Page generated in 0.10166 seconds (77.45% PHP - 22.55% MySQL) with 10 queries |
