OMG what have I done? - Page 2 - diyAudio
Old 12th December 2007, 08:49 PM   #11
Pbassred's Avatar
Send a message via MSN to Pbassred
I am an idiot,
Mistake 1/ I failed to test the amp BEFORE I worked on it.
Mistake 2/ I failed to feed the amp a good signal from a mixer. Instead I used a Jack plug wired to 2 pins of an XLR.
Mistake 3/ I measured the temperature difference at different gain settings.
ACTUAL amplifier fault:
the left side amplitude LEDs aren't working! The amp itself runs sweet as a nut. I could still use the manual though, since I have NO idea how the LEDs work.
Jeeees! I only asked
https://www.facebook.com/dave.potter.5815
Old 13th December 2007, 06:22 AM   #12
In the meantime I have it right in front of me. The "service manual" actually only consists of four pages (two of which are schematics). The user manual is larger !!!
Do you want both of them ?
PM me so I know where I can send it to.
Charles
Old 14th December 2007, 12:30 PM   #13
Pbassred's Avatar
I got your files Charles. A public thankyou. Between the 2 of us we have a document that makes sence. When I get a PDF editor I'll stich them together.
I just need to make the indicator lights work. Its interesing the in 1983 Studionmaster regarded pin 3 of an XLR as "in phase". Nowadays pin 2 is hot. Which means that I have always run it out of phase with the outer amp and not noticed. (there is a lesson there).
It also needs to be configured as EITHER balanced OR unbalanced input. Today most amps take either.
It does sound nice though.
Thanks again
Copyright 1999-2017 diyAudio
