#21 |
I think derrived crossovers work for certain things really well. Like processing where you recombine the entire spectrum before the output.
But don't they swell up on the subtracted side if you use more than a 1st order and keep the signals split? Making the driver have to work harder as it gets closer to the crossover frequency. |
#22 |
By it's nature, the subtractive filter is flat, no 'swell-up'. This is also what I saw in my sims (over on the Carlos bi-amp thread) and I think I was getting more than 1st order (didn't measure the slope of the line though)
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig. |
#23 |
I'd double check that. While it is mathematically flat after you recombine the signals the subtracted FR alone will look swolen as you increase the slope of the filter.
| active crossover state variable filter | les winter | Multi-Way | 0 | 23rd June 2009 02:31 PM |
| LM555 as variable frequency oscillator | xyz9915 | Everything Else | 1 | 17th June 2009 01:10 PM |
| Variable feedback to enhance damping factor at low frequency | svokke | Tubes / Valves | 8 | 7th June 2007 05:14 PM |
| Variable center frequency filter | metal | Solid State | 26 | 18th November 2005 09:12 AM |
| Variable frequency low pass filter | pk386 | Chip Amps | 11 | 25th September 2004 02:43 PM |
| Page generated in 0.09090 seconds (74.21% PHP - 25.79% MySQL) with 10 queries |
