My NAD C320 would not turn on instead staying in protection mode (red LED). Opening it revealed that the 2 smoothing capacitors 15000µF were badly fried.
I simply replaced them and fired the amp on and the amp now works BUT it takes about 2 minutes (annoying) for the LED to turn from red to green. Once on it works fine and has been on for a few days. It comes on almost instantly once warmed up. I was advised that I probably needed to replace more electrolyitcs as I may not have resoled the problem fully. I have now replaced all 4 capacitors on the rectifier board and all in the power amp, power supply and protection circuit itself apart from 2 C420 (33µF C320BEE manual shows this as 100µF)) and C421 (4.7µF) which I did not have but the amp still takes 2 mins for the relay to click into life. I only have a C320BEE service manual and I have checked the Idling current on both channels to be fine (3-5mV) BUT the Output offset on the Right channel is around 55mV (30mV is the max according to C320BEE manual) though Left output seems fine at 25mV. I cannot reduce this offset voltage as VR11 is already fully anticlockwise. Please help |
#2 |
I have just added a schematics for the protection circuit if its of any help. Cheers people
#3 |
audio |
| Help me to fix my nad c320: need a res value | hehe31 | Digital Source | 6 | 4th February 2011 06:03 PM |
| nad c320 | reddish75 | Solid State | 3 | 16th September 2008 02:05 PM |
| Nad C320 Psu? | skenwrick | Solid State | 0 | 3rd February 2006 02:37 PM |
| 6 channel Speaker Protection and power on delay | sachi | Chip Amps | 6 | 18th November 2005 04:58 PM |
| SPK protection delay to close circuit | ckwong99 | Solid State | 1 | 28th October 2005 03:09 PM |
| Page generated in 0.07637 seconds (72.52% PHP - 27.48% MySQL) with 11 queries |
