A limiter...help!... i need your help...Houston!... i have a problem!
Old 7th December 2007, 11:28 AM   #1
destroyer X is offline destroyer X  Brazil
destroyer X's Avatar
Default A limiter...help!... i need your help...Houston!... i have a problem!
You can be the one will help me a lot.
The problem:
My daugther use Satelite receiver all day long... she is a teenager... and together the bubble gum she stay all day long in front of the television.... home teather switched on and five speakers pumping loud sound.... i told her the limit...but!...there's a technical problem my television set volume limiters could not face.
When advertising enters, between program parts, breaks.... the volume is increased by the Satelite Systems Television provider in many decibels.... so.... the damn thing start to scream very loud... also the equalization goes to midranges where our ears are sensitive...man!...this bothers a lot!
The solution i am searching for:
Line level amplifier with limiter... transistors, discrete one, not sophisticated, not using Integrated circuits, Field Effect transistors, schmidt triggers, thresholders, companders, compressor or something expensive and Broadcasting quality.... negative about that...i want simple limiter... clipping with diodes, with NFB... will transistor operating as variable resistance into the input, draining signal to ground...well...i want to keep those peaks controled...cutted... held into some maximum presetable...
But please folks...simple...no 15 transistors, many stages with references, comparators, and so on...i need simple, to DIY..dirty thing operated with batteries.... small thing to help me
The one that offer me a good circuit will be called my dear Santa Klaus.
The solution:
A circuit... a sketch...not ideas...something ready to go..,or ready to test..or ready to simulate...or already tested.... simple!
Your attention with me.... please.... loose some minutes to help me folks!
regards,
Carlos
Dx unbeatable amplifiers; https://www.youtube.com/watch?v=u4tGBiqMnzQ
Old 7th December 2007, 11:41 AM   #2
mitch90 is offline mitch90  Canada
Hello.
This should work.
MITCH.
Old 7th December 2007, 11:47 AM   #3
Default Nice Mitch.... thank you.... can you suggest a transistorized circuit to do this work
Not an integrated circuit, or not using double simetrical supply.
Something even more simple...can you?
I thank you by the nice idea...but i will try, if possible, to avoid chips.... i do not like them..... do not ask me why.... have not empathy to them.
I know the symbol means amplifier stage....so...not a really chip...but chip amps have nice gain and usually are drawed also this way
The symetrical supply makes me think the chip will work better in this way...also the gain controled clipped with the diode.
I would be MORE happy with transistors.... 3 or 4 to each channel and a 9 volts battery feeding energy to them..only one battery.
Of course.... if i could not find a more simple idea...your idea is accepted to try...seems very good...thank you very much my friend.
regards,
Carlos
Old 7th December 2007, 11:54 AM   #4
Nordic is offline Nordic  South Africa
Nordic's Avatar
How about setting sensitivity to about equal what a diode can manage, and then put a diode across the input...
Old 7th December 2007, 11:58 AM   #5
Default This works dear Nordic.... two diodes opposite direction...clipping to 0.6 volts
But distorts a lot when operating.... so.... i will be bothered by excess of distortion in the place to be bothered by the increasing of volume.
I hope people can suggest something a little bit better in audio quality result.
thank you dear Nordic.... i am glad you runned to help me dear Nephew.
thank you by your effort into Dx amplifier group buy.
Congratulations
regards,
Uncle Charlie
Old 7th December 2007, 12:05 PM   #6
Default Hey Nordic... send me some wind from South Africa!
It is a hell hot here.... i will have medicines to reduce blood pressure.... temperature is going to 33 degrees centigrades into this moment.
regards,
Carlos
File Type: jpg time to have a blood pressure controller.jpg (18.6 KB, 246 views)
Old 7th December 2007, 12:07 PM   #7
Donk is offline Donk  Europe
Donk's Avatar
Hi Carlos,
Check this out!
http://www.pira.cz/enlter.htm
Nice simple and cheap design - with PCB published! Two transistors, one IC, and a few capacitors and resistors.
I already built for a VHF (CCIR-FM) broadcast transmitter - works just fine.
Do not forget to bypass R1/C2 with a wire.
Best regards,
Old 7th December 2007, 12:26 PM   #8
Default This one is very good Donk.... i like it..will search for the chip...the main problem
But the circuit matches perfectly.
Hummmm...VHF.... i have worked fixing VHF transceivers man...we are buddies about that...fellow!
73/51 if you are a ham.
thank you very much.
Already searching for more simple diagram...not finding something without the chip and the fet, your suggested unit is the elected for a while.
regards,
Carlos
Old 7th December 2007, 12:48 PM   #9
gni is offline gni  United States
gni's Avatar
Terk VR-1 TV Volume Regulator
http://www.partsexpress.com/pe/showd...number=180-330
Old 7th December 2007, 12:56 PM   #10
Default I want to do it by myself... i have many parts, good soldering iron, good glasses
and i love to do those things.
To import gods...with prices in dollar is extremelly hard and expensive to my pocket and bureaucraty system.
I want schematic to produce.
Thank you by the informs dear GNI...but the schematic would be much more usefull to me.
I thank you by your kindness to answer me, and by your attention.
regards,
Carlos
A limiter...help!... i need your help...Houston!... i have a problem!Hide this!Advertise here!
"Houston we have a problem" Isobarik Sub Fearlessleader1 Subwoofers 18 14th December 2005 06:57 PM
Houston, We Have A Problem....... cwoodall Parts 12 13th September 2005 03:31 AM
New member from Houston,TX vidasean Introductions 1 8th August 2005 03:28 PM
"lift off " or "Houston we have a problem" tenderland Tubes / Valves 16 1st May 2005 05:08 PM
Houston,we have problem... Upupa Epops Solid State 47 10th October 2004 12:02 PM
Copyright ©1999-2017 diyAudio
