Old 4th March 2003, 01:20 PM   #21
Netlist is offline Netlist  Belgium
Netlist's Avatar
Originally posted by Dj BASS AMP
can i Change the 2SC2690A/A1220A to MJE340/350 ????
and i need a transistor compatible to 2SC1815/A1015....
thanks it is important..!!
Dj,
No, you can't:
2SC2690A: NF/HF-L, 160/160V, 1,2A, 20W, 155MHz
MJE340: NF-L, -/300V, 0,5A, 20W, >10MHz
The current rating for the MJE isn't high enough.
Same with the complementary parts 2SA1220A/MJE350
Possible replacements:
2SC2690A: 2SC3117, 2SD669, 2SD1563A
2SA1220A: 2SA1249, 2SB649
2SC1815: BC174, BC182, BC190, BC546, 2SD767
2SA1015: BC212, BC257, BC307, BC557
I didn't check the pin-outs. So measure first!
MPS8xxx is ok too, but certainly different pin-outs
/Hugo - Believe 1 day DJ will have a monster amp...or not...
Old 4th March 2003, 01:46 PM   #22
UrSv is offline UrSv  Sweden
UrSv's Avatar
Default Re: !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
I have a goal !!!!! i have amp and some transistors was a explode !!! and in the company that i buy the new parts..... dont have a 2SC2690A/A1220A and 2SC1815/A1015.
so i need a compatible parts.
now i need to know that the compatible of my parts...
2SC2690A/A1220A can i change to MJE340/350 or what ??
2SC1815/A1015 can i change to BC546 or what ?
the O/P transistors i change them already...
from 2SC5198/A1941 to 2SC5200/A1943.
I am sure that some of the more experienced people here would agree but I think there is a reason why they exploded. You see, usually transistors don't explode (or at least I have limited experience with exploding transistors). Maybe you should think about why everything is exploding for you? Very often an exploding amp is an indication of a problem of some sort.
UrSv
Those who say it can't be done should not stop those who are doing it.
Old 4th March 2003, 01:50 PM   #23
DJ,
You must be careful when you are building or modyfying
electronic equipment. First, you can end up with much more
than a few transistors destroyed. Second, and more seriously,
you can hurt yourself!! Believe me, I have also experienced
exploding transistors, exploding op amps etc. when I was
yound and didn't know quite was I was doing. A component
that explodes can destroy an eye if you are unlucky. Electrolytic
capacitors that explode are also very nasty. Fortunately I have
not experienced that, but other have if you search the forum.
Old 4th March 2003, 02:02 PM   #24
Account Disabled
i need more Possible replacements of:
2SC2690A/A1220A or 2SC2073/A940...
thanks for help me.
Old 4th March 2003, 02:29 PM   #25
Netlist's Avatar
thanks for help me.
You can't get those Jap's can't you?
Will be difficult with BD's or American types;
I'll see what I can do.
/Hugo
Old 4th March 2003, 02:43 PM   #26
moamps is offline moamps  Croatia
thanks for help me.
c3298/a1306 or c2344/a1011
not direct replacement but very close
zzeenn
Old 4th March 2003, 02:55 PM   #27
UrSv's Avatar
Originally posted by Christer
DJ,
-- snip --
Electrolytic
-- snip --
I have done that (please don't check the Electric shock thread). I cleaned up the mist and goo off the workshop but mum still screamed when I came back into the house. I looked like a spotted owl with black spots all over my face from the electrolyte. Big bad.
UrSv
Old 4th March 2003, 03:13 PM   #28
Netlist's Avatar
zzeenn
If the originals are not on a heat sink this will work.
The pin-out is different:
2SC2690A: ECB
2SC3298/2SC2344: BCE
To DJ: If you can only get few transistors where you live, that's sad, but the shop that sold you the big transistors should help you out with what he's got. Simply because we cannot know what he has...you see.
/Hugo - has no shop, only limited knowledge
Old 4th March 2003, 06:24 PM   #29
2SC2690A: ECB
if BJTs must be NO-JAPAN i think only MJE15030/31 can work satisfactory. I use them once like drivers of MJ15003/4, was OK.
What you think?
zzeenn
Old 4th March 2003, 06:55 PM   #30
Netlist's Avatar
What you think?
Moamps,
The replacements you list will probably work, but if you read post
#10 you will see the flare in DJ's amp.
So DJ must replace transistors, this time he will not build a new amp.
This means the replacements must fit mechanically and I don't know if your substitutes will do. You can't turn around a TO220 on a heatsink without a lot of hassle, and DJ already has trouble enough.
I also think that he doesn't have much choice in buying what he would like to buy.
/Hugo - Flips BJT’s now and then, without flares till now
Looking to Purchase ZTX653 & ZTX753 Medium Power Transistors dtm1962 Swap Meet 0 11th April 2008 08:29 AM
Large Cone/large VC or several medium sized cones / medium VCs vajolet Multi-Way 14 3rd December 2007 07:10 PM
change busted output transistors Tarzan Solid State 0 8th June 2004 09:34 AM
Medium-fi amplifier biasing Circlotron Solid State 1 24th July 2002 03:44 AM
Page generated in 0.12355 seconds (81.00% PHP - 19.00% MySQL) with 10 queries
