#71 |
Hi AndrewT
Thank you very vey very much. I will try those suggestions Guillermo |
#72 |
Hi
I´ve done changes. AndrewT:T6 could be replaced with a To92 dual transistor multiplier. The first To92 could be on the common sink fitted to T7+T8, the second could be on the main outputs heatsink. My questions, which configuration, darlington, Sziklai? Opinions? Thanks |
#73 | |
The dual transistor is a pair of NPN+PNP series connected at the emitters. Base to Base resistor is VR. Base to collector resistors ( one to each Q) can be ~1k0 to 2k0.
regards Andrew T. |
#74 |
Banned
GEirin,
it looks really nice now. But BC560 and 2SA1360 should form a simple current source, please!!! |
#75 |
Banned
GEirin,
you need PNP devices there. This is another possibility: |
#76 |
Hi, AndrewT and Lumba, thanks very much.
#77 |
AndrewT
Which is the advantage of this tipology? This tipology is suitable for asymmetrical amplifier? Thanks. |
#78 |
Banned
GEirin,
Eirin, you could consider the diamond buffer output: |
#79 |
Lumba Ogir
Advantages? Diamond buffer output vs. CFP driver Ef output? |
#80 |
Banned
GEirin,
right. Considerably greater linearity, also greater thermal instability. |
| a thanks & HT sub UPDATE | pne123 | Subwoofers | 0 | 15th February 2004 03:26 PM |
| JLH Update | GringoAudio | Solid State | 6 | 8th March 2003 06:12 PM |
| Big Day Out Update | griff | Everything Else | 9 | 13th June 2002 12:39 AM |
| A40 update | doktor | Solid State | 0 | 11th February 2001 12:05 AM |
| Page generated in 0.10628 seconds (81.57% PHP - 18.43% MySQL) with 11 queries |
