Old 24th February 2008, 12:28 PM   #31
Send a message via Yahoo to linuxguru
And finally, the simulated LTSpice AC sweep from 10 Hz to 10 MHz:
Edit: I forgot to mention, it is biased in Class-AB at the edge of Class-B, and
sounds quite exceptional - crystalline highs, mellow/open mids, and controlled but not excessively boomy lows (probably sonically similar in some respects to AKSA 55W without the Nirvana+ upgrades).
Old 24th February 2008, 09:04 PM   #32
AKSA is offline AKSA  Australia
LXG,
Very nice amplifier, congratulations!!
Expect an email.......
Ciao,
Hugh
Aspen Amplifiers P/L (Australia)
www.aksaonline.com
Old 24th October 2009, 01:43 AM   #33
GEirin is offline GEirin  Argentina
Hi all.
My actual design is attached below.
Any comment for improvement are welcome.
Thanks.
Guillermo.
Old 24th October 2009, 01:56 AM   #34
Other option:
Driver: CFP and EF output.
Old 24th October 2009, 06:14 AM   #35
1) The BD139 in the VAS is probably too slow and has a high Ccb - you probably need to use a much faster NPN device like a 2sc2705 or 2sc2240 at that location. The PNP can be just about any medium power device.
2) The bootstrap from the emitter of the upper driver transistor is interesting - I need to simulate it to understand it; I haven't tried that topology before.
Old 24th October 2009, 11:36 AM   #36
Hi Linuxguru.
Thanks for you reply.
"I need to simulate it to understandit". OK.
I can´t to simulate circuit. I wait for you simulate.
Guillermo.
Old 24th October 2009, 01:28 PM   #37
destroyer X's Avatar
Default Schematic is almost the same we have into the DHR Turbo
And if DHR Turbo sounds fine.. this one will sound fine too.
Coincidence or not... accident or not, you have made (created, calculated) the same amplifier.
All those amplifiers, deeply inspired into the published Aksa 55 simplified schematics, sounds excelent...in special because the bootstrap technologie used to feed current to drivers and output.
You do not need, even to simulate..just do it and will sound very good, distortion will be low and performance very high.
Aksa amplifiers, as source of inspiration is a guarantee!
regards,
Carlos
Old 24th October 2009, 02:47 PM   #38
Hola hermano.
Hi.
YES, the inspiration of my lin topology version is a evolution the RCA; Phase Linear; AKSA´s; DX´s; Roender output;TGM and others amplifiers. My actual intentions is to improve the VAS stage.
Saludos
Guillermo
Old 24th October 2009, 05:52 PM   #39
MJL21193's Avatar
2 things I'm not seeing:
First, the resemblance to the DHR turbo, other than they are both amplifiers.
Second, the improvement in the VAS.
<My recommendation> Try a single device VAS, but make it a good one - fast, low Cob good beta.
Old 24th October 2009, 06:03 PM   #40
Default I do not remember very well if RCA was the first to use
I think and English factory for guitar amplifiers made amplifiers this way first...do not remember the brand and model (for a while)... was around 1969 i think.... well.... very cloudy memories... this was a long time ago.
The VAS was explored too into the Precision 1.... the protection transistor BC547(Q7) and the 22 ohms resistance (R19) was because of Andrew T.... sounds better without that resistance.... he said would be dangerous...the VAS could burn...i have tried and have not burned..but i have included the protection into the schematic, to offer more reliable things to forum folks.
A pity that we have exausted, along those last years, all the options (variations) about the good amplifier topologie...i would like to have something new to assemble.... maybe patchwork will be an option, has interesting differences to explore listening.
Good luck!
regards,
Carlos
a thanks & HT sub UPDATE pne123 Subwoofers 0 15th February 2004 02:26 PM
JLH Update GringoAudio Solid State 6 8th March 2003 05:12 PM
Big Day Out Update griff Everything Else 9 12th June 2002 11:39 PM
A40 update doktor Solid State 0 10th February 2001 11:05 PM
Page generated in 0.09662 seconds (82.53% PHP - 17.47% MySQL) with 11 queries
