#91 |
Another designs
#92 |
Another
#93 |
Banned
#1 is very bad.
#94 |
Hi
I´ve done changes. Any comments are welcome. Could someone run a simulation my amplifier. Can anyone help? Thanks |
#95 |
Hi all.
#96 |
Would you be interested to learn how to run simulations ?
If you have a PC type computer you can download for free a very good simulation tool that is quite popular by people on this forum - meaning that you can get some help using it. go here: Linear Technology - LTspice IV Downloads and Updates
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig. |
#97 |
d1 & d1 should be parallel not series.
1360 is not suitable as driver.
regards Andrew T. |
#98 |
Bigun
Thanks for you reply. But I'm a diy not an expert in electronic. GEirin |
#99 |
Hello AndrewT.
Thanks for you reply. Why 2SA1360 is not suitable as driver? • Complementary to 2SC3423 • Small collector output capacitance: Cob = 2.5 pF (typ.) • High transition frequency: fT = 200 MHz (typ.) GEirin |
#100 |
the complementary pair are not suitable for driver duty.
They are excellent for VAS duty and for pre-driver duty. Choose a higher power, higher current pair for driver duty. Try between 20W to 60W AND between 1A to 4A The 1360 is only 5W and 50mA
regards Andrew T. |
| a thanks & HT sub UPDATE | pne123 | Subwoofers | 0 | 15th February 2004 03:26 PM |
| JLH Update | GringoAudio | Solid State | 6 | 8th March 2003 06:12 PM |
| Big Day Out Update | griff | Everything Else | 9 | 13th June 2002 12:39 AM |
| A40 update | doktor | Solid State | 0 | 11th February 2001 12:05 AM |
| Page generated in 0.11470 seconds (74.32% PHP - 25.68% MySQL) with 11 queries |
