Old 23rd November 2003, 09:18 PM   #91
janneman's Avatar
Location: Where Germany, The Netherlands and Belgium meet
Originally posted by grataku
Frank,
why everytime someone talks about Hiraga you get so hot and bothered?
Why didn't you bring up this Stax issue before? The Monstre has always been regarded as one of Hiraga's designs. What's the big effin deal?
If you read the text, it's Hiraga reporting on the Stax Le Monstre at the Tokyo Show. Right, Frank?
Jan Didden
Old 23rd November 2003, 09:26 PM   #92
janneman's Avatar
The one and only:
Old 23rd November 2003, 09:52 PM   #93
diyAudio Senior Member
fdegrove's Avatar
Indeed it is, Jan.
If there's sufficient interest I'm willing to have a stab at translating that page and post it for you all.
Here's a link with the complete diagram and PCB layout:
AMPLI LE MONSTRE.
There's also a British site with partial translations but I can't seem to find it right now.
Maybe some of you know about it already?
Frank
Old 23rd November 2003, 10:40 PM   #94
dimitri is offline dimitri  United States
dimitri's Avatar
Send a message via ICQ to dimitri
Default Hiraga in English
Dear Frank,
here it is:
http://www.tcaas.btinternet.co.uk/hiraga.htm
Old 23rd November 2003, 10:47 PM   #95
Default Le Monstre - amp with true name
It's crazy to see amp without any protection, which have power rails connected to the battery 45 - 170 Ah (!) or to the caps 200 G. It's crazy see amp with this power supply which have power lines on PCB only 1 mm wide, where, if output is shorted, current flow is 13 A. Is the question, what break first - this line or 5 W resistor. In front of your burning house you can to think about : " Is Le Monster this amp or is Le Monster Jean Hiraga ? "
Old 23rd November 2003, 11:07 PM   #96
He. he.. Maybe these traces work as a fuse?
Jarek
Old 23rd November 2003, 11:50 PM   #97
Default Power traces
To Jarek : Yes, but it is " pig work " - and all state test laboratory will be look at this the same.
Old 24th November 2003, 01:46 AM   #98
fdegrove's Avatar
Dear Frank,
Ta. That's the site I had in mind.
I wouldn't count on it and they're not 1mm traces either.
Shrek,
Frank
Old 24th November 2003, 03:05 AM   #99
grataku is offline grataku  United States
Jan and Frank,
so which one is it? Not that I care one way or the other. The so called "monster" is essentially identical to the 20w hiraga le classe A and is being attributed to Hiraga in some way or another by Bonavolta and others.
I can read French good enough to read the following:
with this prototype Stax shows that the "hyper-powerful" watt, the "hyper-transparent" watt (note of the translator: who reads this crap anyway?) of a quality that surpasses the majority of the best tube amplifiers, exists
However, Hiraga takes this design under his wing and developes it in this article and in the second article where he is happy to indicate that a number of amps have been built.
Old 24th November 2003, 03:41 AM   #100
fdegrove's Avatar
so which one is it?
Inspiration: Stax, perspiration: Hiraga and Co.
Historically, d'abord le Monstre" et ensuite L'Hirage 20W Classe A monsieur.
Stax's idea was to prove, once and for all that an amplifier using solid state devices could be made that could possibly outperform the legendary 300B tube amps.
Legendary at that time in Japan at least (my edit).
And what a monster of an amp it took to even attempt to prove just that. (my comment)
They also wanted to make clear to the public that it was better to have a few "quality" watts than to have a ton of garbage watts.
Yes, and as he develops the article he also points out that a number of the parts are already obsolete but crucial to the sonic result and that passive parts are crucial just the same.
For a while " La Maison de L'Audiophile" ( the sales branch of the cleverly set up triangle) offers the parts as a kit.
To my ears the Hiraga 20W Class A design betters the "Le Monstre" but that, my friend, is just my auditory opinion.
In a nutshell, I can dig up a few Hiraga designs from old issues of that mag and they all have one thing in common: musicality.
PRATly yours,
Frank
PCB hiraga 20w ninoslav Solid State 0 22nd March 2007 10:58 AM
"Monster" Cable vs Monster Vintage MonsterVintage Everything Else 0 19th October 2004 12:35 AM
HIRAGA - 'The monster' PCBs kristijan-k Swap Meet 0 28th February 2004 03:12 AM
Help for an Hiraga Monster project gavroche Solid State 5 18th November 2001 02:20 PM
Page generated in 0.11820 seconds (82.35% PHP - 17.65% MySQL) with 11 queries
