Old 28th November 2007, 02:36 PM   #1
Unhappy Preamp Question!
I have build some active monitors. Problem is that the levels dont go high enough to match the audio level of my other speakers. Only single phono/RCA channel preamps I can find all say that they are for turntables. Will they still work if my input is not from a turntable?
I found this one, and in all of the specs it says "allows you to adjust preamp gain for a wide variety of input sources".
I dont want to buy a 10 channel rack mount preamp for this one channel.
Old 28th November 2007, 04:45 PM   #2
PigletsDad's Avatar
Pre-amps for turntables are not suitable. They have a special frequency response, and follow the RIAA curve, with masses of bass boost and some treble cut.
I think you just want a standard line stage. The simplest thing I can think of is 1 opamp, about three or four resistors, some coupling capacitors, and some sort of power supply.
Google for line stage.
Old 28th November 2007, 05:02 PM   #3
paulb is offline paulb  Canada
This will work:
http://headwize.com/projects/showfil...=cmoy2_prj.htm
Also see this for general information
http://tangentsoft.net/audio/
Old 28th November 2007, 08:04 PM   #4
I cant find much of anything on "Stage Lines" (in english). Did find a few though, they are all high dollar.
I thought about using a headphone amp and just using some RCA converters. I dunno' about building my own though.
Old 28th November 2007, 08:12 PM   #5
I found a couple of things that maybe you amp guys can tell me about.
This guy seems to make just what I need, and its THD% rating is great.
"The Pure III" preamp/headphone amp
I would make something like this, seeing all of the parts come with it. Getting all of the correct parts is the biggest issue for me. Do you all know much about these Ramsey kits? Sound quality is very important to me. Think this is good?
Ramsey Headphone amp kit
I figured I could change the 1/4" jack to RCA's when I made it.
Old 28th November 2007, 11:27 PM   #6
Gordy is offline Gordy  United Kingdom
Although I don't know about the Ramsey company, the unit looks fine for $30 (/ £15). (Don't forget to buy the power supply too).
Old 28th November 2007, 11:48 PM   #7
I have 6 or so "wall wort" power adapters ranging from 9 to 12 VDC. This says it works on 9 to 15 VDC, so one of mine should work.
Old 29th November 2007, 12:35 AM   #8
Originally posted by Lab_Rodent
The-Pure-III-DC-Coupled-Extreme-Low-Noise-Headphone-Amp
This is the same as the Cmoy amp project I posted. You could build one yourself, especially following the guide in the other link I posted.
Ramsey-SHA1C-Stereo-Headphone-Amplifier-Kit
This is based on an LM386 low power speaker amp, and is not very good quality. Not recommended.
If you do want to buy something, the Cmoy-type would be better. You can use your wallwarts for it.
Old 29th November 2007, 12:49 AM   #9
nogoodboyo's Avatar
There are some very nice looking pre-amp kits at www.twistedpearaudio.com
Old 5th December 2007, 11:14 PM   #10
Thought I would go ahead and share my slightly modified Ramsey Preamp/headphone amp. As you can see I made it so I can just plug in RCA's instead of having to use the headphone jack. It works great, just what I needed.
Uno preamp question john blackburn Chip Amps 14 15th February 2010 10:26 PM
preamp question sakis Solid State 4 17th July 2009 11:28 PM
preamp question overdrajv Tubes / Valves 7 28th December 2008 05:49 PM
X0 preamp question Tyimo Pass Labs 5 25th March 2007 08:32 AM
Preamp Question mapiao Tubes / Valves 0 6th February 2007 02:41 AM
Page generated in 0.11431 seconds (79.36% PHP - 20.64% MySQL) with 10 queries
